Speedometer just disappeared .....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Can'tWait, May 31, 2011.
  1. Can'tWait
    Can'tWait Junior Member
    30
    Michigan
    Over the weekend I was driving on the highway....all of a sudden the gas and mileage indicators along with speedometer just disappeared....any fellow Prius'ers noticed this?
    I am curious what the solution is; the car is warranty so hopefully no cost repair but if it happens after warranty is over I'd imagine it would cost a bit...
    Thanks
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you didn't knock the dimmer switch, then you might have a bad POR circuit in your combination meter. PM peef about it.
  3. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    We need a Wiki page for stuff like this. This is a very common question.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Just make sure nothing slid over the projector part like a bussiness card or something.
  5. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    "Why officer, was I going over the speed limit"?
    M67v likes this.
  6. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    +1 on that, and check the dash light dimmer (thumb-wheel located low and to the left of the steering wheel).
  7. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Surely dash light can't totally black it out. Sounds like OP can't see it -at all-.
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    If the thumb wheel for dash lights is turned all the way down and you turn on the headlights you loose everything except the warning lights. Just turn it up past the click for day time driving.
    If that isn't the problem it needs a trip to the dealer. Several people have had a failure of one side or the other.
  9. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    How and where would something have to be to block the projector from displaying that data ?
    Just curious/.
    Thanks
    REV
  10. tumbleweed
    4,067
    691
    Eastern Oregon
    The left half is a mirror with the projector mounted down in the dash. You can block it with a piece of paper, try it.
  11. qbee42
    3,079
    The most common cause is turning on the headlights with the dimmer wheel turned down. With the headlights off, the dimmer wheel doesn't do anything, so it's easy to turn it down without noticing. The next time you turn on the headlights the display goes black.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes it can. Try it. ;)
  13. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    And, don't call me Shirley. :D
  14. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    The same thing happened to me last fall driving to VT. The left side of my display went black - no speedometer, instant mpg, gear info or gas tank level. I took it to the dealership & they replaced the board that controls the display, shaking their heads as to why only 1 side when out since the board controls both the left & the HSI on the right.
    I've seen other reports of this problem here at PC.
  15. Can'tWait
    30
    Michigan
    So..here is how it was resolved :)
    Took it local dealer - they kept it for a week and gave me a free loaner car.
    They found both upper and lower circuit boards/plates in instrument cluster burnt out. It was free replacement/repair since car is 2 yr old with 28K miles.
    If this happens after warranty, I'd imagine it will cost some real $.
    Thanks for all the insight.
  16. jdenenberg
    jdenenberg EE Professor
    3,937
    1,934
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If this happened out of warranty, there is a tech in northern California who goes by the name pEEf here on Priuschat who repairs these boards at low cost. He works with a very good auto repair company in northern California, Luscious Garage.
    JeffD
  17. smurs
    smurs Junior Member
    43
    Iowa
    +three!! This just happened to me too!! It was pitch black out and all if the sudden, I lost that whole instrument cluster (fuel gauge, speedometer and shift indicator). I almost crashed into the curb looking for the speedometer. Didn't realize how much I look at that. I pulled over, made sure the dimmer knob was up (it was and all other indicators were working fine). I power cycled the car and that didn't help either. It is hard to drive in darkness without a speedometer! Was going to take it to the shop but when I went to my car a few hours later, it was working again! Very unsettling, this car is brand new!!
  18. jim256
    jim256 Member
    317
    69
    Eastern NC
    Did something slide over the recess in the dashboard below the speedo? It reflects from below into a mirror.
  19. smurs
    smurs Junior Member
    43
    Iowa
    No, it really went out.
  20. Mendel Leisk
    41,000
    Just thinking: go back twenty years and this thread wouldn't make much sense.
    Karen Mollins and BaxterBasics like this.
