LED lowbeam observations
Discussion in 'Gen 3 Prius Technical Discussion' started by autom3tro, Jun 5, 2011.
  1. autom3tro
    autom3tro lumenphilia
    San Jose, CA
    hey guys, this is for those who ever wondered about individual output pictures. I spent time recently making observations on Prii with LED lowbeams, hope this excites you :D
    First-both headlights on wall:
    Second-single headlamp on wall: (i used passenger side)
    Third-upper parabolic reflector (flood light, foreground)
    **observation, it appears that the reflector has a shielding to reflect residual forward light (often lost) back onto the reflector:
    Fourth- Projectors (combined) without top parabolic reflector:
    Fifth-Only outer/smaller projector: (diffused beam/mid-distance)
    Sixth-Only inner/larger projector: (focused beam/distance)
    The dark downward spike on the left side of the output is my girlfriends hair...
    **observation, apparently this also sources the "squirrel finders," though both of the projector lenses have a texture on the inside/flat surface instead of the round outside facing surface. Think of fresnel lenses but instead of having circles, they're vertical lines covering the backside of the projector toward the led unit.
    On the Prius i studied, the large projector also showed signs of melting and damage on the large projector as seen here:
    possibly all LED-equipped Prii will suffer this?
    many LED lowbeams that were studied all showed the same signs of melting inside of the larger/inside projector (focused beam). A fellow member on a light enthusiast site also discovered that tilting the projector at the right angle on a not-so sunny day can also start making the insides burn.
    The Prius's led lowbeam internals are mostly plastic to save on weight.
    Here is another batch from a member, Upashi, who is also studying the headlamp:
    top from left, small/outer diffused projector, large/inner focused projector, and reflector part. bottom, combined beam
    3 people like this.
  2. Thai
    Thai Prius Neophyte
    1,197
    89
    I have no idea what you just said...is there a layman's conclusion to all these tests?? Thanks.
    The internal melting...hmmm, does this mean that ext warranty is a good idea?
  3. autom3tro
    San Jose, CA
    lol my bad, this is just for those who ever wondered how each of the 3 led sources contribute to the overall beam.
    as for internal melting, look inside the larger projector and check to see if there's any form of burning/melting, 3/3 prius's i've seen showed mild-to-moderate signs of damage.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I wonder if this lens could be replaced with a high temp glass lens. Due to the differance between the 2 mediums, the glass less will a little diff in size.
    The queston is, is there a glass sub that could be used!!
    Very nice write up by the way. I was wondering how the 3 lamps interacted with each other.
  5. autom3tro
    San Jose, CA
    ty :) problem is that the lens isn't what is melting, it's the internal "beam shaper"/cutoff shield. The lens is causing the inside of the projector to melt because it's focusing sunlight into the projector. reverse optics >.<
    ALSO the lens is fused to the projector, so replacing it with another will require extra cutting and work. hopefully Toyota recognizes this and tells Koito to make improvements because this setup is also on Lexus's Rx, Hs, and Ct model hybrids, as well as the Asian market Toyota Sai.
    2 people like this.
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Here's a diagram showing the LED headlight pattern and such:
  7. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    Simple solution: use duct tape to secure a Wal-Mart plastic bag to the headlights for daytime use.
  8. autom3tro
    San Jose, CA
    woops, forgot to add in, the culprit (the sun) attacks the headlights during early and late days when the angle of the sun is in line with the projector (or relatively in-line)
  9. Tideland Prius
    16,508
    Which is, depending on the season, the times you want your headlights on to be seen. This is interesting. Toyota has had issues with melting plastic on the Gen 2 brakelights and thus the switch from a black housing to a chrome housing for 2006. I wonder if they'll make changes to the LED headlights for the midlife update.
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks you for posting this information!
    So the shield is melting but the bowls seems ok?
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Looking at the beams again it's seems like it is difficult to get all the headlights to focus in a clean manner and cover all of the important areas. The width doesn't seems that great nor is the cuttoff clean. At least there is some bleeding at the top of the cuttoff for lighting up street signs or squirrels. :)
    That being said, the shots I've seen on the street seems like they do a good job of lighting the area up. Thanks to Tideland for supplying his pics.
  12. qbee42
    3,079
    Always park facing north (in the northern hemisphere).
  13. autom3tro
    San Jose, CA
    The bowl's are alright, it's just the additional beam shaper mirrors that deflect residual light into usable light, same ones seen on a lexus ls600h:
    I took these pics at around a 5-8 foot distance, if you go back further, to around 15-20 feet, all the beams should align relatively nicely (as seen in tideland's street and wall pictures. The LEDs have a more homogeneous light coverage, providing wider view with good distance (if you adjust the beams a tad upward) than the halogens. With the halogens most of the light is directed in center and distance.
    F8L likes this.
  14. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    If anything within the assembly needs replacing (including burnt-out LEDs), the entire assembly is replaced, to the tune of $800 a pop. Has there ever been a case of "internal melting" leading to premature failure in the Lexus models? If not, I doubt there's anything to worry about.
  15. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    There are no heatsinks for the LED?
  16. autom3tro
    San Jose, CA
    yes, there are heatsinks for the LED's. The melting is due to optics from the sun shining into the projector to melt the internal reflector (beam shaper/cut-off shield not bowl).
  17. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Because of the heat LEDs generate in headlight applications, heatsinks are a must from what I have always understood.
  18. autom3tro
    San Jose, CA
    F8L, i just noticed, you're on HIDplanet too
    F8L likes this.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yup. :)
    Thanks for the explaination too. Could one paint the beam shaper white to reflect insolation? I assume this would only affect "lens color" if viewed from a high angle.
    32kcolors, I don't think this melting would cause light failure. It would change the way the light looks on the road but I doubt the average Lexus driver would notice the difference unless it was pointed out to them. In fact, the loss of the beam shaper might make the lights appear brighter (like a high beam).
  20. Thai
    Thai Prius Neophyte
    1,197
    89
    Ext. warranty won't cover headlight bulbs...but i wonder about the headlight assembly?? And since apparently LED is kinda tied in with the whole assembly, then would ext. warranty pay for damaged internal reflector??
