ClarianLabs: Rethinking The Battery As A Tiny Engine
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cyclopathic, Jun 14, 2011.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Horrible article; innovation is basically combining Wankel with electric motor is one package.
    Granted there are Wankel Atkinson cycle geometries, but kinda doubtful given the thermal losses, efficiency and environmental issues. Maybe Mazda would build one
  2. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Mazda has clearly demonstrated over years and years now that rotary engines suck (guzzle oil, terrible fuel economy, terrible longevity). Perhaps in this application they wouldn't, but it would be a first.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Lets break down by function the main reasons why HSD improves fuel economy:
    * Coasting with ICE off
    * ICE downsized by having alternative extra power source
    * Markedly decreased low power pumping losses
    This invention can substitute for the last two I think, and maybe the first also. Since it appears to be quite small, perhaps super dooper composites, carbon or ceramics may be employed to solve the friction problems of past rotaries.
    I am not a scientist or an engineer, so take my post with a grain of salt. I do.
  4. mmcdonal
    mmcdonal Active Member
    666
    98
    Columbia MD
    This is basically how a motorcycle engine provides an alternator. The crankshaft is the rotor, and the stator is mounted on the crankcase. How is this any different? Except it is a less efficient engine?
    Why not just turn an old turbo into an alternator? Just put it downstream near the tailpipe. Still, there is back pressure, but your fuel is already burnt instead of providing new fuel. Just a thought.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Admittedly I'm treading in unfamiliar waters for myself, and probably out of my depth. So I'll ask anyone and everyone...
    If I'm reading this correctly? Why is it compared to...or called a "battery" at all? It's a "Rotary Piston Generator" by the manufacturers own definition. Then they "say" it's energy "capacity" is 10 times greater than a battery? But what do they mean...immediate output capacity, when fueled and in use? Or energy "storage" capacity...
    Because admittedly I'm ignorant here...but how does this device "store" energy? They simultaneously call it portable energy storage...I'm not seeing the "storage" part? They seem to be using two terms...generator...one thing....and battery..another...
    Enlighten me. Which is it?
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ As I posted above, I think the idea is to replace the battery in a hybrid vehicle application with this device. I don't know if it can also act as a flywheel, but maybe that is the capacity talked about ?
  7. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Actually, you still need a battery (or UltraCap) for efficiency. This is an approach to doing a serial hybrid
    JeffD
  8. qbee42
    3,079
    The battery comparison is because the device can be made very small, which would allow it to power some of the same devices traditionally powered by batteries.
    A better title for the article would have been: "Tiny internal combustion engine targets traditional battery applications."
    It isn't a battery. It doesn't have anything to do with batteries. It *is* small, and it generates electricity. That is the end of the similarities.
    This device would be entirely unsuitable for hybrid vehicles. In fact, rather than use this, one can use the engine already installed under the hood. Batteries are used in hybrid vehicles because they can store energy. This tiny motor can't do that.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    same more info:
    Clarian trumps Bill Gates with rotary-piston hybrid battery - GeekWire
    reading all this and still confused.
    I could see this replacing battery if you use rotary as hydraulic pump and package it with hydraulic high/low pressure tanks
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    Oh ... ok.
    Perhaps people willing to make hydrogen at home and refill their own cartridges will be interested in the device as a way to store energy. As for car application the extra power supply might allow ICE downsizing, ICE off coasting, and solve low power inefficiencies. Seems like regen is lost.
  11. qbee42
    3,079
    This device *is* an ICE. Therefor it won't help for ICE downsizing, ICE off coasting, or anything else ICE. It's just another motor-generator, albeit a very small one. It won't be small if you scale it up to the size needed for a car. Then it will be essentially a Mazda powered Prius.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    ^^ I was thinking of it as the battery replacement in a hybrid drivetrain. A bigger_ICE/little_ICE hybrid, if you will.
  13. qbee42
    3,079
    I understood your thinking, which is why I replied like I did. If you replace the hybrid battery with another ICE, you end up with a two-engined car, not a hybrid. Adding a large version of this device to a car is just adding a second engine. In no way can it serve the same function as the hybrid battery. At best, it could work like a trolling motor on a fishing boat.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    Tom,
    Ignorance is bliss -- I have not given up on the idea yet ;)
    How about this: HSD, little_ICE, big_ICE, and ultra-cap. The ultra-cap is needed for regen and eCVT duties.
    I call it a hybrid because the two ICEs can work alone or in concert.
  15. qbee42
    3,079
    That would work. Even with just the ultra-cap and ICE it would be a hybrid.
  16. The Electric Me
    9,083
    5,801
    Thanks...it was early in the morning and I was just misreading/misunderstanding the title. I kept thinking...why are they calling it a battery? But now it makes sense..they are saying...You could use this tiny "engine" to generate electricity, then use it in applications commonly used for batteries...Yeah, it's a misleading title...
  17. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    you gotta love the new anti-leaf comercial showing how you can run everything on propane and not plug it in:confused:
    Well there is one good use for it. It looks like you could add this to a ev to convert it to a serial phev. This is the approach audi is using on one of their prototypes, a small wankel generator to range extend.
  18. bisco
    51,851
    so, this would be like the leaf commercial asking " what if everything was powered by gasoline?" instead of having a battery, my laptop would have a butane tank and enough of these generators for power. would i have to duct the exhaust outside?
  19. austingreen
    13,671
    4,209
    Austin, TX, USA
    I"m thinking "what if you were wireless". So you can walk into you office in the woods, and just turn on the quiet generator and power and internet without wire. . etc. I know I really like having a gas chainsaw to clear land without cords. I also like having a camping blender that runs on gas. My camping stove runs on propane. It would be awful to carry around heavy batteries, or be unable to get out in nature.
  20. qbee42
    3,079
    No, the exhaust would go into your lap, enhancing the already hot cooling air venting from the computer.
