Wheel Width 18 by 8.5 fit?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 78mao, Jun 20, 2011.
  1. 78mao
    78mao New Member
    SoCal
    Hi guys, I have a Gen 2 and I was wondering if 18 by 8.5 all around would fit? I like the Forgestars F14, but the narrowest they come is 18 by 8.5 and I have did some search everyones running 7.5 or 8 in the front and just want to see if any other members here have ran 18. 8.5 !
    Really appreciate your guys help!
    Thanks!
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    @ 8.5" you'll probably have to roll your fenders.
  3. 78mao
    78mao New Member
    SoCal
    i think the outside should be fine, im worried about the inside if it might hit the strut or not.
  4. macmaster05
    4,050
    730
    well, then you do spacers, in which case you still might need to roll fenders. what's the offset?
  5. 78mao
    78mao New Member
    SoCal
    They are custom offset, so I can request for whatever offset they offer. what would you suggest?
  6. Gruppe-S
    Gruppe-S Junior Member
    27
    Lake Forest
    Don't forget tire size will affect the offset you need to run. What tire size were you thinking? You might have to stretch some tires too.
  7. 78mao
    78mao New Member
    SoCal
    yea I understand, so maybe just minor stretch of 205 on a 8.5?
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Don't stretch the tires. Looks terrible. Use the proper tire width for the rims.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Here is a wheel offset calculator. You need to know the offset ofthe OEM wheel currently on the car.
    Wheel Offset Calculator
    You could try a 225/40/18 tire. That would be very close to OEM diameter.
    The ContiTouringContact CW95 is a LRR tire in that size but it doesn't have a good treadwear rating and it's pricey at $196/ea..
    The Continental ExtremeContact DWS is a favorite of the guys with 18" wheels and they are only $144/ea..
  10. GloryThief
    GloryThief Junior Member
    59
    The Westside
    2013 Prius v wagon
    Take the measurement of inner and outer clearance. Use the offset calculater and you'll then know what you can run and what offsets you'll need
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
  12. peterjmc
    917
    189
    Clarksburg, MD
    Late reply and the answer that the OP asked is probably OBE.
    I run 18x8.5 with a +48 offset.
    245/40 and 235/40 tire size will rub in the front if you are lowered. 245/40 will rub in the rear but 235/40 you miiiight be okay. 235/40 is still a bit wide but might be narrow enough to not rub. With 245/40s I did not have to roll fenders.
    With that said, If you are running 18x8.5 you should be okay with 225/40 up front and more than okay with 215/40s and not rub.
    +48 is the perfect offset to have the front wheel flush with the fender. A 5mm spacer could be used in the rear if you don't like the look of your wheel possibly tucking into the fender well.
