ICE stays on AFTER 25 miles of driving???
Discussion in 'Gen 3 Prius Main Forum' started by jnodarse, Jun 20, 2011.
  1. jnodarse
    jnodarse New Member
    Miami
    Hello everyone, I drive about 25 miles each way to and from work in South Florida. Almost since the day I've purchased the vehicle (6 months), I've learned and used the Pulse and Glide technique daily and I've become very good and comfortable with it. I usually get 65mpg on my way to work and 70+ on my way home.
    However in the last couple of days, I've notice a significant drop down to low 50's with no change in my driving habits, route, or tire pressure. Also no work or maintenance has been done to the vehicle. Upon closer investigation, I've noticed that sometimes, well after the warmup stages, when I glide, the ICE stays on and the instant MPG meter only reads 50mpg instead of the infinity mpg it usually does. It doesn't happen everytime I glide, just sometimes. For example this morning after driving the entire 25 miles to work, the ICE stayed on during my last glide of the commute. At first I thought that maybe I didn't let my foot off the accelerated long enough, but further attemps with longer delays resulted the same result of the ICE not shutting off.
    I'm stumped. Has this happened to anyone else? Should I have the dealer look at the car? Am I missing something?
    Thank you in advance for your help
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Air conditioning perhaps?
  3. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Turn off the defroster. You probably aren't using the heat but turn that off too.
    Also, make sure you are doing a proper glide (barely using any battery, nor doing any regenerative braking) instead of doing what is commonly known as stealth, which is just driving under battery power. If the battery is low, the engine is on.
    OK, also, it's not uncommon after I have done an extensive P&G session (100 MPG+ for >5 minutes), with very long glides, that the engine is cold enough it wants to warm up again.
  4. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    How does the traction battery indicator look? Does it look constantly discharged? Perhaps below 50%? After driving 25 miles it should show 75% IF your driving on the interstate. Like one member said, heavy A/C usage (while not in ECO) could cause the engine to stay on if traction battery levels are low.
  5. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
  6. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
  7. jnodarse
    jnodarse New Member
    Miami
    Thanks for all responses so far. Here are some additional facts in response to questions.
    Toward the end of my 25 mile commute I have a 5 mile stretch of highway so ICE runs during that entire time (I don't P&G on the highway). That usually always results in a high traction battery level (as was the case this morning). Immediately upon exiting the highway, I drive about 2 more miles through a local neighborhood which is where I tried to glide and noticed that ICE stayed on.
    I did use the A/C the entire trip this morning but on the lowest setting. I don't use the defroster. The battery indicator was high when the incident happened.
    I definately released my foot off the accelerator completely and then pressed slightly (no regen and slight electric). And when I saw the ICE stayed on, I released my foot again for a longer duration, and then again. All three times the ICE remained on even though i was barely pressing the accelerator.
    Please keep your ideas comming as I appreciate all your thoughts.
  8. mikewithaprius
    656
    103
    Rhode Island
    Hey GSW,
    The "warmed up" part of my post popped up automatically from the link I provided, since it's the title of the thread - I didn't type that. I agree the car would be fully warmed up.
    Since it's possible for the engine to be quite hot while still in stage 3, I'm wondering if he may not be in stage 4. Even though it seems unlikely, jnodarse now said his last bit of driving is through a local neighborhood, so it may be possible it's at speeds under 25 mph, where stage 3 would keep the engine on.
    The AC also sounds like a very good suggestion, I would try that first, and the stage 4 thing as a later option. Let us know if you get it resolved, jnodarse.
  9. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    I'm not sure on the 2010. But on the Gen-II Prius if the battery temperature gets too hot, it will stop allowing use of any all-electric drive. I would guess it is the same on the Gen-III. There are people out there who have hacked the battery fan to run all of the time in order to prevent the battery from getting that hot, allowing more stealth mode and EV mode driving during the Summer.
    I think 25 miles was around the magic number for my 2008's battery to get too hot.
  10. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    If you come to a stop does the ICE turn off? You said you had the A/C on the lowest setting? I'm pretty sure if you have it set to Max A/c the ICE will continue to run, just set it to like 70 or something like that.
  11. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Just a few thoughts:
    Check to see if you have the HV battery vent blocked somehow
    Perhaps you should borrow a Scanguage to see the ICE coolant temp. It perhaps may be a faulty temperature sensor.
    Within 2 miles it is entirely possible for the car to drop back into Stage 3 if you are gliding enough and there are lights. What are morning temps and is the air slightly wet (drizzling, foggy, etc.)?
  12. macman408
    1,179
    367
    +1 to adric22; I've definitely had mine go easy on the battery and run the engine more when the battery gets hot. For me, this typically happens when going over mountains - so I drain the battery (on purpose) as I approach the top, then charge the battery fully on a nice downhill section, then drain it going back up, then charge it... It gets hot pretty quick when it's near full. It also can happen if the car is, for example, parked in the sun and very hot. And if there's something blocking the battery vent (either something covering the vent, or dust or small kids' toys or whatever clogging the ventilation behind the cover), that will make it worse.
    You might consider running the air conditioning a bit stronger, to see if that helps. The battery is happiest at temperatures that are comfortable for people, too - say 70°F or so. (On the other hand, it also draws more power from the battery, but if you're just barely comfortable in the front seat with the vents pointed right at you, you can bet the battery is unhappy in the back seat.)
  13. Mendel Leisk
    40,472
    Or maybe a faulty thermostat? Not sure what's in the Prius, but traditionally there's a thermo-mechanical thermostat. It's closed when the engine is cold, to bring it up to temp quickly, then opens to allow coolant to circulate to the radiator. If it's stuck open, you could be cooling too efficiently, especially when travelling at highway speeds.
    Because the Prius lacks a engine temp gauge, you would need a Scangauage or something similar, to check coolant temp.
  14. jnodarse
    jnodarse New Member
    Miami
    Last night, it didn't happen all the way home. But it did happen again this morning when I was 11.5 miles into my morning commute. I was going 45 mph, the battery level was high, the A/C was on low and the outside temps were in the 80's (just plain muggy). From what I recall when I stopped the ICE turned off. I think it happened again on the very next glide attempt (so two or three in a row). But all the prior and subsequent glides were normal. I did turn off my a/c after the incident.
    I just read all newer posts now, and these are all great ideas. I had no idea about the HV battery heating up to the point where it blocks all electric.
    Summarizing all the new ideas, it could be:
    1) A bad thermostat or tempature sensor (I don't know anyone with a scanguage to check this. Maybe dealer)
    2) overheating HV battery due to either a blocked vent (very possible b/c I have kids) or just not cold enough in vehicle. (where exactly is the HV Battery and it's vent?)
    I will try to find and look for vent blockage and i will also run a/c colder and I will see if either of those help.
    Thanks again for all these great ideas. I'll report back with results.
  15. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The main battery is just behind the rear seat and below the trunk. If you lift the removeable floor of the trunk and the cargo tray below it, you can see where the main battery is and also where the 12V battery is.
    The intake vent for the battery ventilation is between the right rear seat and the door
  16. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    That's where it is, on the right hand side in the non-folding portion of the cushion of the rear passenger seat.
    Make sure if you have pets or whatever that it's not clogged with fur or dust.
    I mean, really make sure that you don't have the defroster on. That includes the "Windshield and Feet" setting on the fan position selector. I only use "front" or "front and feet".
    A good test to check engine temp is to see if you can go into EV mode when you are above 12 mph and below 24 mph.
  17. Mendel Leisk
    40,472
    The layer of carpetted floor directly over the main battery is a bit of bear to pull off, but it can be done. There's about 5 push-in fasteners, and one 10mm (socket size) bolt, the latter by the rear seat pillow. An automotive panel tool or two is needed. Some of the fasteners will likely pull out of the floor part in the process, but likely without damage.
    If and when you do get it off, you can pull all those tough fasterners out (label and bag them). The remaining alignment pins and the 10mm bolt are ample to hold it down.
    Once you've got that off, a bit more plastic ductwork removal and you can check the fan's condition.
  18. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    I think the good test is the ability to use pure EV mode during your trip - maybe you will see same diagnostic message on display.
    The scan for DTC codes can be usefull as well. if DTC memory is clean, the exact diagnostic wiill need experienced dealer's technician. who is familiar with exact car operational condidtions and able to diagnose the problem by reading the Techstream data.
  19. jnodarse
    jnodarse New Member
    Miami
    Almost too embarrassed to ask this dumb question but I'm still learning so stick with me.....I'm confused why I would be checking the engine temp. Is that a check to see if the tempature sensor is bad? For example, if I can't enter EV between 12 and 24 mph after 25 miles than that means that the sensor is not reading the correct temp and may be reverting the Prius back to warmup stage 3?
    This board is awesome. I've learned so much about my Prius because of this board....and I've got a long way to go....Thanks everyone.
  20. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    Great suggestion on trying EV mode!
    I was thinking to ask whether you're using ECO mode, or not; didn't see you specify that. ECO mode will minimize use of the compressor, and allow more EV-only operation.
