My DIY oil change tips
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by onerpm, May 6, 2005.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I learned to drive up in Dawson Creek, start of the Alaska Hiway and we have the same winters as the Peg and I drove there for 6 winters and then moved out to the central coast but 60 miles inland and winter happened there also. Lots of snow, the hospital had a deal with the phone company if they got more than 4 feet of snow over night the Ph com. would pick up the worker in a Nodwell Flextrac. in the 2 winters that we spent there never had more than 2 1/2 feet over night. City cleaned snow with an 988Cat with a 12 yard bucket on it. I never had any trouble driving in either place, but your aunt in PoCo has the right thought. Down here when it snows it's not me I'm worried about it's the other 1 1/4 million no minds that don't have a clue how to do it. Save a few retirees from Sask. and Manitoba. The rest have trouble and I mean trouble driving in the rain, of which we get a bit.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Frank:
    That's pretty much how my Auntie in PoCo describes it. Though she moved out there in the mid 70's, she hasn't forgotten her ingrained winter driving skills. It's just that nobody else around her has a clue.
    The big thing for this 70 year old woman now is all the young punk no-minds who cut her off on city streets and even on the Coq. Connector. She has started shaking her fist at them and shouting a comment that rhymes with "duck shoe."
    Personally, I think she had better move to a nice small town with a lot less stress. Before she conks of a stroke or something.
    Yeah, if you learned to drive up in Dawson, you're qualified to handle snow, ice, gravel, and even potholes.
    BTW my dad told me of one exciting time in Jan the heavy truck he was driving froze up near Dawson. The #2 diesel he had from the States froze up that is. He tried to make a fire to get the fuel to ungel but naturally set the tractor on fire instead.
    He's a nice guy, and he means well, but he's a bit of a klutz. Last time he tried to fix a toaster, he caused a minor kitchen fire.
    Jay
  3. azw
    azw New Member
    28
    Thanks for the thoughts, Galaxee.
    The convenience of the Mityvac--especially in being able to easily pour the oil into a closed container--attracts me. I've been draining the oil into an old round pan. Pouring the oil out is a real test of my so-so balancing skills.
    Of course, I'd still have to crawl under to pull the filter, and it's almost certain I'll get hit with the oil doing that.
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    someone else mentioned poking a hole in the filter with a nail and letting it drain. since the filter is designed to always be full of oil and not allow for back-drainage, it is a tough thing to pull a filter and not get oily. maybe try the nail thing and the mityvac and who knows? you may not even get dirty :)
    let us know how it goes
  5. prberg
    prberg Member
    155
    Burbank, California
    Question about adding the 'sure-drain' or fumoto valve onto the Prius. I haven't seen how low they hang so that might keep me from putting it on if I'm afrid it will hit something.
    But my real question regarding those valves... do they get all the dirt and grit out of the pan? When you pull the regular drain plug I would think that some dirt and grit that is in the pan would flow out... but with these valves and the smaller hole that the oil has to flow out of... does that dirt and grit get stuck in the pan forever?
    I like doing the oil changes myself... but I hate the mess that I make. In the end I probably get at least a cup of oil spilled onto the driveway. (I do put down rags but it stills manages to get on the ground.) Are these valves (the Fram one in particular) a bad idea? Will it not get all the gunk out of my engine? Is it a big risk that it will get hit by something and leak oil? Should I use the included copper washer or one of the toyota washers?
    thanks alot,
    Peter
  6. onerpm
    onerpm New Member
    477
    MN
    Peter, I put on the SureDrain at the first oil change I descibed in the original post, and used it at my 10k change. I'll be using it again at my 15k change due in the next week or so. I also had it on previous vehicles. It's wonderful...now I have mess-free changes. It doesn't hang down too low, it's just slightly bigger than the original drain plug. When I take the cap off and screw on the second piece that allows the oil to drain, I don't use the included 4-inch piece of orange hose.
    Can't answer your q about the gunk coming out. It does drain more slowly with the SureDrain than originally.
    When I couldn't get the oil filter off the first time because I didn't have the cap-end wrench yet, I ended up punching a hole and draining it because I knew I was going to mangle it trying to get it off with the tools I had at hand. I don't like the punching hole thing, though, because if for any reason you fail entirely in removing the filter, what do you do then...you can't drive it to a mechanic!
    To avoid mess on removing the oil filter, once I have it loosened a bit, I cut off the bottom of a 1-liter coke bottle (I think it's the 1-liter, I always forget, could be 2) and stick that on the filter and unscrew it with my hand holding the bottle. The drips from the oil filter go into the bottle, and if you accidentally tip the filter a bit while getting up, the spillage goes into the bottle.
    I don't remember that a washer came with the SureDrain, but if one did, I used it and not the Toyota washer.
    And, DanMan, my OP comment about your head was definitely a reference to your large brain! :lol:
    rob
  7. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I've the Fumoto valve on both of our Prii ('04 and '05). Does NOT hang any lower than the original nut, that I can tell. It may appear to do so, since it's so shiny and looks different. With the Prius being a low to the ground car to begin with, I'm much more careful when encountering obstacles anyway.
    They work great. Plain and simple. Takes a push up on the small lever (up and over a 'locking' groove), then a rotate to get the oil to drain. I have a fairly short oil drain container that just fits under w/o jacking the car.
    Couldn't say on the 'complete' drainage/gunk question. I've done 6 changes with the valve, filling with 3 qts. Mobil 1 syn amd it seems to end up right smack dab in the middle of the dipstick every time.
  8. nickb
    nickb Junior Member
    45
    Soprano State
    If you use a torque wrench you don't have to worry about any problems with the drain plug. I have been using one for a while now. I originally started using them when dealing with motorcycles that had aluminum parts that can strip VERY easily.
