Anyone else find the clock is fast on their 2010?
Discussion in 'Gen 3 Prius Main Forum' started by DetPrius, Jun 24, 2011.
  1. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Each time we adjust for daylight savings time, I reset my Prius to an atomic clock and a couple months later I notice it is gaining compared to my cell phone. I just checked the Prius against the atomic clock and in about 3.5 months it has gained 2 minutes and 8 seconds. Anyone else find the same? I thought by 2010 we had figured out how to design a relatively accurate clock at a reasonable price.
  2. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Yeah Set mine with the cell phone every 3 months or so! Don't know if its a Toyota trait or what! my Toyota Yaris does the same thing.
  3. qbee42
    3,079
    Drive faster; that will slow down the clock.
    2 people like this.
  4. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    haven't noticed, but maybe it is... my wife has the habit of having our alarm clock 10 to 15 minutes fast and her car 5 or 10 minutes fast... I thought she had gotten to my car as well.. Maybe the bugger was just fast... have to check that out!
  5. fuzzy1
    10,412
    But we can always save a few pennies by making it a little less accurate.
  6. El Pollo Diablo
    El Pollo Diablo Junior Member
    28
    Maryland
    I noticed the clock in my Prius is about 5 minutes faster as well...I thought it was the dealer whom set the clock incorrectly.
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I tried that, but the red and blue shifts seem to converge in the mirrors.
  8. fuzzy1
    10,412
  9. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    had to reset clock the other day and it was several minutes ahead. Same with Dodge, so don't thinks it is Toyota only issue.
    The lower temperatures make clock run faster due to quarts thermal expansion.. Perhaps Toyota clocks are tuned to higher avg temps?
  10. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    On a tour of the PJM Interconnect many years ago, I learned that grid frequency is already being adjusted (e.g., boosted ~0.5Hz overnight) to help keep the system in sync, so this isn't new news, unless the magnitude of these adjustments will be changing.
  11. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    :dance:
    Thank you, Prof. Einstein! ... relatively speaking, of course.
  12. fuzzy1
    10,412
    That is the point of this news: the magnitude of the adjustments will be changing sharply:
  13. samsprius1
    720
    182
    2023 Prius
    Limited AWD-e
  14. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Actually, it's not just the magnitude: It's the average value. Cycle-to-cycle time on the 60 Hz grid has never been very good (speaking as a person who actually worries about +-1.6e-8 variations in clocks in his day job), but the long-term average clock has always been purposely nailed to the National Bureau of Standards banks of Cesium clocks, Hydrogen Fountains, and other esoteric means of Knowing Just What Time It Is. Hence, that $5 cheap-as-nails alarm clock/clock chip that monitors 60 Hz power in order to keep track of time has been just as accurate as the NBS, at least for waking one up in the morning. Now all these manufacturers will have to invest in a $1 oscillator to get something reasonably accurate. For people who worry about the numbers of tenth of a cent surface mount resistors, that's a major expense. Since, natch, that $1 oscillator will probably ending up being around 30% of the total cost of the electronics.
    Now they're going to permanently unlock the system clock and leave it that way. That gets rid of all the tedious mangling around with the phase over time to get back in sync with the NBS, which is probably what they're really after, but it means that gazillions of alarm clocks and such could be (worst case, not likely) off by 20 minutes or so after a year of this.
    So, given that I'd bet that 20 or 40 million power-line style clocks get sold in a given year, we'll all end up spending $20 or $40 million bucks a year over time to end up with semi-accurate alarm clocks, the power companies will save a couple million or something not having to keep the power clocks locked, and that will be that.
    KBeck
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    20 minutes/year worst case is still about as good as you will get with a cheap consumer level crystal and assembly line tuning in a clock.
    For those who want more accurate time, cheap WWVB clocks seem to be good out to around 1,000 miles from Ft Collins Colorado.
  16. kremlin
    kremlin Prius is a religion, not a car
    Maine
    The same: 2 days ago I had to roll back my clock 5 mins. Strange, huh???
  17. qbee42
    3,079
    Stop using Pulse & Glide.
  18. macman408
    1,179
    367
    2 minutes and 8 seconds over 3.5 months is actually pretty good; that's only 14 parts per million off. Probably the most common oscillators used are rated for around 50ppm - though to be fair, the Prius very well may have a 50 ppm oscillator, but because it's not being subjected the most extreme conditions possible (according to the oscillator specifications, anyway), it's performing better than that.
    There are a lot of things that will affect these oscillators; temperature, voltage, age, vibration, acceleration... And cars are not known for being well-controlled in any of those aspects.
    Now in general, these effects can be compensated for in a variety of ways. But doing so makes the oscillator bigger (a few mm to as much as several inches or more), more expensive (do you want to pay an extra $10-$100?), more power-hungry (and who wants their 12V battery to die because it was keeping time?), etc.
    The best way to keep accurate time is really to use a broadcast signal; this is what most cell phones do, though it depends on the cell phone company having the right time. It can also be pulled from one of several low-frequency radio broadcasts; WWVB in Fort Collins, CO covers most of the continental US, DCF77 covers a large amount of Europe, and there are others elsewhere. GPS signals contain accurate time information as well. Unfortunately though, each of these options costs money, adds complexity, and may not even work well - for example, the low-frequency radio stations often can only be received late at night, when the car is likely to be in a garage surrounded by a lot of house, and the signal may not be strong enough for the car to receive it.
    So yeah, they can make a better clock, but for most people, it's just not worth it.
  19. macman408
    1,179
    367
    16 nanoseconds? That's ages! My work is generally more concerned with picoseconds, usually up to no more than a few hundred of them at a time. (A picosecond, or 0.001 nanoseconds, is enough time for light to move 0.3 millimeters, at most.) :D
  20. fuzzy1
    10,412
    I don't allow ordinary surface mount resistors that expensive to stay on the bills of material I review.
    And in some applications (past for me, not present), even a picosecond is hideous phase noise.
