Sporty looking Dash Kit?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by kp3649, Jun 26, 2011.
  1. kp3649
    kp3649 New Member
    I'm looking for a "sporty" looking dash kit. I don't want any wood grain because I don't think it really fits the car that well. I was thinking something a little better than what was already there. Maybe carbon fiber, but I feel like that is over done. Maybe there is another choice that is something different.
  2. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    Well, you could go brushed alumimum, but then that would look too similar to that "silver" trim. You could try going for this look, as seen on the Lexus IS-F, but I wouldn't know where to begin to source the material:
  3. kp3649
    kp3649 New Member
    Yeah I really like whatever material texture that is, but like you said I have no idea where to get that. Also, I'm not sure what pattern that is. Maybe it's like a silver carbon fiber?
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    You can buy precut carbon fiber sticker kits for the Gen II Prius. However, the problem is it looks very tacky IMO. Since they don't wrap around the entire piece of panel or piece of plastic, you can totally tell it's just a sticker.
  5. Tideland Prius
    16,464
    I believe Lexus calls it white carbon fibre trim, so you're pretty close.
  6. kp3649
    kp3649 New Member
    Yeah you are totally right about it looking tacky, and thats exactly what I don't want. I just don't know what to do to make the dash a little more interesting. Any other suggestions for any type of dash kit at all??
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Why not cover the dash in the fabric of the uniform of your favorite sporting team? Wouldn't that look "sporty"?
  8. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    Chicks dig bearskins. Oh yeaaah.
  9. patsparks
    10,664
    567
    not when I take MY shirt off they don't.
  10. qmtran
    qmtran Junior Member
    87
    Seattle, WA
    If you are thinking about wrapping / changing the plastic parts, try 3M DiNoc vinyl wraps. I have seen this done to many cars and the results looks great. Can't really tell it's fake unless you are really looking.
    If you are trying to change the texture of the dash covering, you can get some custom microsuede/leather done by some companies online. Not cheap.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I've been using some of it. For polyproylene/polyethylene plastics, which is what most of the hard interior plastic in a Prius is, use 3M 94 Primer on all the edges and any areas that have residual tension on them that is trying to pull them lose from the surface. Like concave areas and places it had to be pressed into place as it was stretched to install it. The primer is about $20 delivered froom ebay for 1/2 pint but you use so little if you just do the edges and stretched areas that it will go a long ways,
    It does look good. It has a dry carbon fiber look to it, and is available in several colors. 3M also has a shiney version of CF textured vinyl now but I haven't seen it in person
