2010 Oil Level on stick V.S. Owners Manual 4.4 Quarts specs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010priusowner, Jun 26, 2011.
  1. 2010priusowner
    2010priusowner New Member
    37
    FL
    First off sorry if this has been answered here before but after alot of searching I have found nothing.
    I just did my first oil and filter change M1 0 W 20 at 5,000 miles ran the car with 4 quarts in it using the A/C and Heater alternately to get the ICE to run
    ( by the way how do you put a Gen 3 in maintenance mode saw it mentioned but not explained.)
    Checked for leaks none found buttoned everything up and lowered car on level surface.
    Installed remaining oil .4 quarts per spec
    Showed low on the dip stick just as in this video where the guy says this is proper.
    To my knowledge the marks are on the dipstick for a reason does full not mean full anymore or is it just arbitrary?
    Checked oil again this morning still at same level, did a 20 mile run today and checked again oil level the same, still shy of full on the dipstick.
    What is correct? Please see video I am confused, is this guy correct?
    Overfilled oil in a Toyota Prius. | evtalk
  2. Mendel Leisk
    41,406
    I did first oil change about a month back: drained thoroughly, replaced filter, put in 4 liters, then 0.2 liter additional. Made a point to run the engine for a minute, to circulate oil into the oil filter, then rechecked. 4.2 liters is the same as your 4.4 US quarts.
    For me this put the oil level right on the full mark, when I rechecked the next morning. This is actually a bit higher than I'd like, and I resolved to only use 4 liters next time. You could probably get away with just 4 US quarts, for that matter.
    I found the dipstick very hard to read on this car, very prone to smearing. Best viewed in bright sunlight, and flip it over, check both sides, check more than once.
    Also, make sure you're on level, or near level. Most garages have slight slope, for drainage, but not significant.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    4 qts has been enough for me... puts it halfway between the marks.
  4. 2010priusowner
    37
    FL
    Thank you sir, In FL It is all level ground for the most part. And sunlight this time of year is a guaranteed curse! Maybe I drained more than usual by jacking the car up so high making it a dry fill?
    Yes the M 0/20 is very thin and hard to read on the stick.
    I would say squinting and 5 reading later only 3/4 of he stick is populated with oil. Better a little low than high but still I use torque wrenches and prefer to be correct.
    What did you make of the video?
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    4 quarts brings mine to halfway between the two marks on the stick
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you check your oil level in the morning before you start the car with the engine cold, the thicker oil makes it much easier to see the oil level on the stick.
  7. Mendel Leisk
    41,406
    I don't know why, but the Prius dipstick is very smear prone. The actual level is down at or below the top mark, but there are streaks running up the edges making it hard to discern. And fresh 0W20 is almost like water on the dipstick, very thin and clean.
    I've checked the oil level on our previous HCHII recently (was babysitting it), and it is much better in this regard. Maybe a little streaking further up the dipstick, but minor, and there's a definite stop, at the true level.
    I don't see having the vehicle tilted making a difference to how much you drain. I would go with the other responders: dump in 4 quarts, run it a minute to fill the filter, do a quick check but don't get to excited about it: it will be good.
  8. 2010priusowner
    37
    FL
    I just checked it again this morning as was suggested the oil is thicker and yes smear prone to the full mark is a very good description.
    I am very likely to permanently remove that silly oil door as others have posted I hate the idea of having a potential leak without seeing it on the ground just filling up that shielding.
    This move to no longer using canister type filters is Poorly implemented the location is terrible Mercedes-Benz has used internal filter replacement for decades but at least they have the good sense to put the damn thing in an upright position where you can reach it by raising the hood unscrewing a bolt on the canister and remove the filter, seems to me TOYOTA got cheap on us trying to implement the canister type filter placement.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I use 4.3 quarts which leaves it just shy of the full mark. I check my oil in the morning before the car has been run, pull out the stick and look. If I wipe it off and put it back in it will smear.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Our Kia van has the canister/element type but like the MB, it sits on top of the engine and makes oil changes so easy/clean .
  11. 2010priusowner
    37
    FL
    Checked oil again this morning same reading. I wonder why 4.4 to 4.5 quarts did not bring it to a solid full mark. Very tempted to put more in and bring that reading true to the top dot on the stick.
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Your case sounds little extreme, but...there is a big stack-up of tolerances that effect a dipstick reading. Some are:
    Capacity of the oil pan due to variations in the casting or fabrication.
    Location of dipstick hole in block
    Depth of dipstick hole in block
    Fit of dipstick tube in block
    Length of dipstick tube above block
    Markings on dipstick
    Position of stopper on dipstick
    How much oil was drained
    How accurately filled the oil bottles were
    How much of the oil was actually drained into the engine
    Toyota makes good stuff, but not one of those dimensions are perfect, they all have intentional design tolerances.
  13. 2010priusowner
    37
    FL
    I did have the car jacked up pretty high and let it drain for what seems like forever I guess the best thing to do is measure my waste oil as I have not taken it to the recycle center yet. Messy but probably the only way to tell of course there will be some small variation but not 1/2 quarts worth.
  14. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    That's what I would do. Trying to figure out what happened seems like a lost cause--and the important thing is how much oil is in there now. I'd fill it up to the top dot. Over time, it's going to decrease, if anything.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you were driving a used car with unknown history, then there would be the possibility of it having the wrong dipstick and other strangeness, but that's not the case, so either fill with 4.4 quarts or fill to the full mark and enjoy life.
  16. Mendel Leisk
    41,406
    Have you been checking the oil level prior to doing the oil change? How was the level then?
    I think in one of your intitial postings you say it's 2/3 of the way up, from the low mark to high mark. That's ok, in any event, I wouldn't bother adding more, just keep an eye on it.
  17. 2010priusowner
    37
    FL
    Yes the oil level always showed up to the full mark dot on the stick, prior to the oil change.
    Measured oil to 4.4 quartes 4.5 at most.
  18. Mendel Leisk
    41,406
    When we took delivery ours was maybe 3/16"~1/4" below top mark. When I did the change I put in 4.2 liters, but kind of regret the .2. It's dead-on the top mark now: I prefer slightly lower.
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I have been using only 4 quarts of oil every oil change and
    have 51,000 miles.
    When I change the oil nearly 4quarts comes out.
    It seems to work well, the oil light has
    never come on....
    alfon
  20. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    If you were at the full dot how much smear up the dipstick would you expect? I am starting to get concerned about the level of oil in my car and it might help explain the econ. troubles we have had.
    This weekend we drove up to Greenville for basically a 200mi round trip hwy jaunt and I could not get above 45.3.
    The oil smears about .5 to nearly an inch past the full point.
    This is the first time they ever used bulk oil on my car, all the other invoices say quarts of 0w20 so I am thinking this is why its so badly overfilled and I am not 100% certain the oil is correct either though they claim it to be.
    So...should I drain and refill? Its only got about 2k on the filter, could I leave it be and just do the oil?
    Just noticed on the invoice it says 5, always said 4 before then. GRRR. Still looking for opinions on draining and refilling with fresh oil and leaving filter.
