Has this happened to you???
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Jun 26, 2011.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    miles: 148.9
    gal's used: 2.067
    MPG Guage: 62.0
    MPG Calculated: 72.036
    Reg. Unleaded with 10 Ethanol
    Hwy 90% 10% City
    Note:
    When I filled last time at slow speed when the pump stops thats it...
    So after 148.9 miles the guage was still reading full. Normally it would drop down to 2 -3 pips from full.
    So I went to the same gas station I had previously filled up, a different pump but the same type and filled at slow speed, first click that was it....
    So I am baffled why. I could see if it took 2.5 gal's but a little over 2 gal's. I have never had this happened. Also the gas guage still read full.
    alfon
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Your variance is amplified by the small amount you filled. It could also be perhaps that such a small fillup causes the pump to stop pumping earlier.
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    The next time you see that kind of mileage early on a tank, continue until empty, then fill up and see what your mpg's is. At the low miles, just a few tenth's of a gallon can make a big difference.
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I will check the next time I fillup. What puzzles me
    is that the guage was still on full....
    alfon
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    A pip is between one and two gallons usually. Add to that, in summer gas can expand a bit throwing off a normal readout. If the gauge shows full and you can put 3 to 4 gallons in, you could have a sticking float.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Probably the automatic shut off was different. Even if you use the same pump it will be a little different from fillup to fillup. Best to check it over several hundred or even several thousand miles toping it up on the first and last tank. You will have to sneak across the border into WA to do that though. :D I know you aren't suppose to top off but a couple of times to check the Cons readout won't hurt anything.
    I checked mine over 3500 miles when the car was new and computed the error of the Cons readout. Now I just use the readout and subtract the error.
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    That is one thing that bothers me about Oregon. You have all these freedoms, yet you can't pump your own gas in your own car...
    Now, if you own a diesel car, and I do, you can pump diesel fuel in your car.
    You can also pump gasoline in your motorcycle. Seems like there is an immediate danger there as any gas spilled will leak down into a hot engine. It would be a lot safer pumping gas in a car as the engine is several feet away from the fill pipe.
    Some things don't make any sense. This is one of those
    things....
    alfon
  8. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Really? You can't pump your own gas in Oregon? I've never heard of that. Learn something new every day...
  9. Ghoti
    Ghoti Member
    101
    Arizona
    Mandating that all gas stations be full service adds several thousand jobs state-wide. In the current economy, that would actually be A Good Thing, in my opinion. When I lived in Vermont, I used full-service stations whenever I could simply to support their existence.
  10. Mendel Leisk
    41,301
    In our municipality, Coquitlam, self-serve is outlawed. It's the only community in greater Vancouver with such a policy. We've lived here over 20 years, and always drive to a neighbouring municipality (no big deal, on our way) to gas up. :rolleyes:
    I recall once walking by one of our local full-serves: the attendant had left the pump on, unattended, and the auto shut off had failed. It was gushing gallons down the side of the car and down the street, great fun...
  11. tumbleweed
    4,067
    692
    Eastern Oregon
    Unfortunately it hasn't worked out that way for us. What usually happens is the clerk at the mini-mart is given the additional duty of pumping gas. The result is the customers get worse service both in the store and at the pumps. There are usually no additional jobs created.
    But jobs is not the reason the law continues to exist. It is to keep card lock stations from selling gas to anyone except their commercial customers. The people who own mini-marts and gas stations don't want to compete with card locks. We had a ballot measure about 10 years ago to allow self service, unfortunately it was voted down, so the people got what they wanted.
  12. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Yes, and I believe New Jersey is the other state that prohibits pumping you own gas.
    Stupid restrictions IMHO, but I suppose they try to consider the lowest intelligence quotient. Like the warning on frozen entrees...."please cook before eating"!
