Economics and Human Fallibility
Discussion in 'Fred's House of Pancakes' started by airportkid, Jul 14, 2011.
  1. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    I do the maintenance for an Aero Club and bill a modest hourly rate. A few weeks ago the alternator brushes gave out in one of the Cessnas so I took the alternator to a local shop & they put new brushes in & I put it back onto the airplane. I also installed a noise filter (capacitor) while I was at it, which necessitated finagling with the orientation of the filter, its lead, and the battery, field & ground leads because that alternator is jammed between the cowling and the baffling and there just isn't a spare square millimeter to pack all that stiff wiring into. I took me about three tries to finally get it all to fit without chafe points and all wiring still slack.
    Shortly afer completing the installaton I noticed the ammeter oscillated like a fan at low RPM but seemed to steady up at higher power settings. The airplane flew for a couple weeks and the oscillations stopped. Whatever it was seemed to have corrected itself.
    After forty years futzing with things mechanical I should have known better. Sure enough late Friday afternoon a pilot called stranded at the fuel ramp. Dead battery. Well, that explained the lack of ammeter oscillation: the last few hours had been flown on the battery only. Fortunately you can hand start an airplane engine (they run on twin magnetos, independent of the electrical system), so I got the thing running and got it to our hangar and in half an hour had the alternator on the bench and the answer in fragments beside it: the remains of the battery terminal post, burnt clean off (along with the terminal ends) by the blowtorch of high voltage arcing. The nut holding the battery lead on hadn't been tightened when I'd installed it, creating momentary breaks in contact that the regulator overcame by upping the voltage until arcing completed the circuit. My mistake. I realized that all those trials getting the leads secured properly distracted me enough I'd forgotten to tighten the terminal nut once I'd succeeded in getting it all to fit. Dumb.
    It was just a week ago I'd told another airplane owner I'd helped get his carburetor put back that 60 percent of what a mechanic does is simply repair what he's f---ked up. How true.
    So here's the 100 dollar question.
    Do I bill the club for my labor putting the alternator right? Should the club reimburse me the $65 it cost to have the alternator shop replace the burnt terminal and bench check both the alternator and the regulator?
    My ethical mind says no - I goofed, I should pay.
    But that same ethical mind says yes, man is fallible; we will always goof, and allowance for the inevitable goof is a cost that should be borne by all of us. The rate I charge the club is modest, less than standard shop rates by more than half. There is no cushion in the rate to serve as a goof allowance (which is part of the reason shop rates are as high as they are, I'm sure).
    I could bill the club only half, and eat the other half.
    Last year I changed a tire and pinched the tube doing it; but the tire didn't go flat until the airplane was at another airport, and that sheer remoteness added $200 to making the fix. At the time I tried to bear those costs myself but the club's maintenance officer said don't be ridiculous, my mistake or not, it was routine club maintenance and the club should pay the full bill, including mine.
    I'm sure he would insist the club pay the full bill in this instance too.
    So - what are your thoughts?
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    At the rates you are charging, you should get a break on corrections.
    But, having worked as a tech on stuff that would kill people if done wrong as a young person, then later as an engineer designing stuff that would kill people if my products malfunctioned, I am concerned about you signing off on an aircraft with a flaky ammeter reading immediately after you did some maintenance on the electrical system.
    Also, fixing a flat without pinching a tube isn't rocket science.
    The "who pays" isn't nearly as important as your focus on your work.
    I realize no one is perfect and you only gave two example out of likely thousands of maintenance operations you have performed, but it does sound like you should focus more on the task at hand.
  3. daniel
    14,487
    1,519
    Spokane, WA
    I say put the question to the club.
    I also say there's no reason you should be working for so little. Less than half of standard shop rates means you are contributing more to the club than other members, unless there are other jobs also being done by members at below market rates.
    If your work is always sub-standard (which only you and the club can judge) then you should resign for the good of the club, and the safety of its members, and advise them, for their own good, to use professional services.
    If these two mistakes are rare exceptions, such as any mechanic will make from time to time, then you should charge standard shop rates, or give the club a 10% "friends" discount below the local market shop rates, and then when you occasionally make a mistake you should not charge to repair your own mistake.
    It sounds to me like your club's maintenance officer has a level head and would probably agree with the above.
    So, charge for the repairs this time, and then tell the club that in future you will not do so, but you will also charge 90% of local shop rates, and then you'll be responsible for your own mistakes. And get insurance, if you don't already have it, so that if you destroy an airplane :eek: you won't be wiped out. :D
    Just my opinion, obviously.
  4. ETC(SS)
    6,924
    Let them read your first post and make the call.
    Good Luck!
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I would say charge for parts, but if you feel that strongly about it, let your time slide for the goof.
  6. mmcdonal
    mmcdonal Active Member
    666
    98
    Columbia MD
    What does your repair invoice say? Is there some boiler plate that covers this? In any event, I would pay for it out of pocket and chalk it up to the cost of an education.
  7. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    My concern would be your liability. If something worse happened, you'd be on the hook for a lot more. Not that you should be prevented from doing something you love, and that you haven't given the issue some thought.
    In this case, it's not enough either way to lose any sleep over. If you and the club are comfortable with covering the parts but not the additional time to correct your mistake, that could be a reasonable compromise. From their point of view, the cut rate for your experience and integrity is still a bargain, and they probably wouldn't mind paying for the extra time. Any one else would have billed the full book time at shop rates, and charged a markup on parts. If you feel compelled, you could always donate it back.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I would thank God no one was hurt or killed. Then I wouldn't charge for my mistake. But that is just me. :)
  9. airportkid
    2,191
    538
    Thanks for all the insightful response. I'll likely introduce our maintenance officer to this thread and we'll discuss. I have to say, the power of the Internet to furnish exactly these kinds of exchanges is an amazingly constructive new social force, for it proffers perspectives from a vast diversity of experience unattainable (and often impractical) from other more conventional community forums. It's one reason I despise trolls with the intensity I do - they only corrupt and corrode this marvelous new tool for strengthening and increasing our general understanding. So many thanks!
    Just after writing my OP I realized I may have given the impression I'm all thumbs with the wrenches. While I'm sure opinions may differ, for what it's worth the Aircraft Inspector I work with has more than once said that when Baird repairs something it stays repaired. To my mind the dangerous mechanic (or other operator) is the one who doesn't do personal and honest post-mortems, who really does think he's infallible.
    I may also have given the impression that light aircraft maintenance is casual or haphazard. While it's true that we don't maintain light aircraft to the same standards as airliners (if we to tried no one but Bill Gates could afford so much as a Piper Cub), it is nonetheless a stringently regulated field where just getting the basic licenses takes several years. There's substantially more to know than basic mechanics - even the most intelligent mechanically astute person would without training commit legal sins, like routing an electrical line beneath a fluid line, or putting a self-locking nut on a hingepin bolt, among many other arcanities of aviation maintenance learned and applied only after someone's blood got spilled.
    But until we program robots to do it for us, we'll continue to make mistakes, even stupid mistakes - out of ignorance, fatigue or just plain bad luck. It's the price for going beyond nature and inventing our own contrivances. The smart ones (I hope I'm one) try to prevent them to begin with, by adding systems for catching errors, such as checklists, but especially by being ruthlessly honest in assessing them when they happen.
    Thanks again.
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There is only one way to never make a mistake, and that is to never do anything.
    I'm glad you do post mortems on your work, more people should.:rockon:
  11. Trebuchet
    Trebuchet Senior Member
    3,772
    936
    43
    Without knowing your modest hourly rate it a hard call. Things also change as to your experience are you rated or a rookie? Can you charge if not rated? If not :eek: please be careful, after the inevitable lawsuit I don't want you to have to depend on Obamacare for your medical the rest of your life! I'm not asking for the rate or a summation of your experience but perhaps a scale would help others here to give a more educated answer.
    Let's say we put it on a the same type of scale that you would use in the present day political environment. :rolleyes:
    So if you modest rate is to the far left in Obama Progressive area then I'd have to candidly say that you should pay for it yourself and then some. To the Right keep it and maybe hit them up for a raise so that you can further your education and not make the same mistake twice but that's an experience issue so read below.
    In the realm of experience once again I'd use the same scale as above and as you've probably already guessed the results will mirror those above. :p
    btw: hand prop a Cessna! :eek: :fear: at the fuel pump, ballsy! :yo:
