GY Assurance Fuel Max Fail
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NC_Prius, Jul 15, 2011.
  1. NC_Prius
    NC_Prius Member
    186
    I realize there are countless tire threads already, and some concerning this specific tire. But I'm wondering about my experience.
    I just traded in a 2008 Prius. Around 22k miles, I purchased GY Assurance Fuel Max tires at Discount Tire. I traded the Prius for a Gen III Prius Three yesterday and kept the rims (with the tires).
    However, the tires are already bad. (I just wanted to keep my rims, but now I need new tires for the new car). They only have 25k miles on them, and the front tires sound like a truck. I just had one rear tire replaced because the belt was beginning to separate.
    Ok, now for an admission ... I never rotated the tires. [Gulp]
    I've had cars in the past where I didn't rotate the tires, and yet, the tires lasted much longer than 25k miles and did not sound like a truck. I chose not to rotate the tires this time because I find these tire shops (and dealers) scratch up my rims. I've even found ratchet marks on my other car's rims, so I know they are simply not careful with other people's property (along with the grease on the inside cloth).
    So -- my question is -- are these tires really that bad, or was the 2008 Prius hard on tires, or can tires really go bad that quickly if you don't rotate them. (BTW -- I never rotated the original Integrities when I bought the new tires at 22K, and they weren't nearly in this bad of shape).
    Should I switch to the Bridgestone Ecopia EP100s or Michelin Energy Savor (AS) [Expensive!] tires instead? The GY Assurance Fuel Max tires are rated pretty highly, and get good reviews. But I want as quiet a tire as possible with good handling, fuel efficiency, traction in all-weather, etc (I don't live in a deep-snow area).
    Or -- is it just the fact that YMMV no matter what tire you buy depending on x number of factors?? Sure makes it hard to know what to get.
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    I've got 8,000 miles on my set of Fuel-Max tires. They've been great so far; however, upon extreme close-up inspection a tiny difference between front & back could be seen when I rotated at 6,000 miles. So, I couldn't imagine 25,000 miles without.
    What PSI were the tires at and how often were they checked?
  3. NC_Prius
    NC_Prius Member
    186
    I've kept them around 45psi because they're rated max is 51. That was per posts I've read on Prius Chat to keep more air pressure in the tires for better fuel economy. I know that could wear the tires down a little more -- but that is their rating. Then again, maybe that just doesn't mesh with the Prius very well? Regardless, I'm still a bit frustrated that the front tires are so noisy. Maybe I just need to try a different tire.
    One other question I left out in my OP -- is it possible that Discount Tire sells tires that have been sitting on the shelf for some time? I've had quite a few problems with tires there, and I almost wonder if they sell substandard tires or something, like a one-off irregular sale on clothes. But I hate to blame them if that's not really the case.
  4. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    I have the GY Assurance Fuel max on my Wife's RAV4. They have about 32k currently with plenty of tread left to get to 50k. The OEM tires were Yokohamas and we got 50k out of those.
    On my 04 Prius I have the Michelin Fuel Savers. After 50k miles I have only used 1/4 of the useable tread. Possibly these will last 200k. I have not rotated them yet because my digital micrometer shows very little difference between the front and rear. I keep them at 45-50 psi and drive 35k miles per year, 75% highway.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    To determine the age of your tires please follow THIS link. Here is a sample:
    Tires Manufactured Since 2000
    Since 2000, the week and year the tire was produced has been provided by the last four digits of the Tire Identification Number with the 2 digits being used to identify the week immediately preceding the 2 digits used to identify the year.
    Example of a tire manufactured since 2000 with the current Tire Identification Number format:
    [​IMG] In the example above:
    DOT U2LL LMLR 5107
    51 Manufactured during the 51st week of the year 07 Manufactured during 2007
    The Prius can be hard on the tires, especially if you tend to drive fast through corners. That last part is true for any tire on any vehicle.
    You didn't mention if you had your alignment checked on the old Prius. The combination of bad alignment and not rotating the tires can reduce the effective life of your tires. This is especially true for the rear tires because the rear suspension cannot be aligned.
    The other idea is that you just received a defective set of tires. It can happen with any tire manufacturer. :(
  6. NC_Prius
    NC_Prius Member
    186
    Are the Michelin Fuel Savers the same as the Michelin Energy Saver (AS)?
    If so, I could also get those at Discount Tire -- but I just don't know if I trust their tires.
    I also put a set of GY Assurance Fuel Max on my Nissan Altima, and they aren't very noisy at all (though I haven't had them on as long). But I bought those at Sears just to see if maybe DT was the problem (although it could have been the Prius). I seem to have had problems so many times at DT that I'm thinking it may be their tires, so I'm concerned about getting even the Michelin's there. I purchased a "free tire replacement" coupon for each tire at DT, and they only replaced one because the belt was separating. But they won't replace the ones that are just "noisy." And, well, if they think the car is the problem, I suppose I could see why. Maybe it was the Prius. I don't corner that hard, but I do a lot of highway driving for my commute. Maybe the extended highway miles puts wear on the tires?
    I guess I could try one more time now that I have an entirely different car. I have one brand new tire, so I would only need to buy 3 more.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Then why not shop at TireRack.com or Costco?
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We have over 41,000 miles on our Energy Saver Tires, 195x65x15. We keep them inflated, all four tires at max sidewall pressure of 44 PSI with Nitrogen, Costco, where we purchased the tires. Rotate every 5-6,000 miles.
    So far MPG's have increased 2-3 mpg over original factory Yoko Avid tires.
    We really like these Energy tires but I am taking a close look
    at the Nokia Entyre which is also fuel efficient with even a longer treadwear life.
    alfon
  9. NC_Prius
    NC_Prius Member
    186
    That's definitely an option. I've purchased tires at DT for several reasons. First, I have bought several rim/tire packages from them. Plus, they are local to both my home and my work -- very easily accessable, quick, etc.
    Another question that I just thought of is -- I've heard some say that certain shops don't balance tires well. Could that also cause this problem? I would think with the machines it wouldn't require much skill.
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    That makes sense. Maybe you can find a shop that will install the TireRack tires AND not scratch your wheels. I make it a point to ask the installer to be careful with the wheels. If you don't say anything then they probably assume you won't notice.
  11. NC_Prius
    NC_Prius Member
    186
    Well, I'm glad to say that the new set of Fuel Max tires are quiet. I just had them put on today. I'm going to try having them rotated as recommended to see if that helps. These rims haven't been scratched like my other ones, fortunately -- maybe since these are aluminum vs the others were powder-coated. Not sure how much difference that makes. Or it could be because I didn't have them rotated before.
  12. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Given the fact that you neglected to rotate the tires, verify alignment of the wheels, or just generally maintain the tires as recommended, it's now impossible to determine the cause of the issues that you're experiencing. Even if it IS a set of defective tires, you've given the manufacturer an out by not even coming close to maintaining the tires as required.
    Of course your new tires are going to be quiet ... ALL new tires are quiet.
    I would just suggest that you maintain the new tires as recommended, keeping receipts to document the maintenance, and go from there.
    REV
  13. NC_Prius
    NC_Prius Member
    186
    Ok, that was a long-winded reply, so I deleted it... Thanks for everyone's suggestions.
  14. NC_Prius
    NC_Prius Member
    186
    Well, it turns out that once I drove on the new tires for awhile, I began to notice at higher speeds that the driver's side front wheel seemed to make a low rumbling noise, like something wasn't right about it. I went back to Discount Tire today and had the DT manager drive the car -- and IF they rotated the front and back tires like they said they did, it made absolutely no difference. Which means -- my Prius might be at fault.
    Before I take it in for service, is this unusual? Has anyone noticed that the left front wheel seems to make more noise than the others (like a low rumbling noise, esp at higher speeds: 45-70 and around curves)? I've ridden on the passenger side and that side as well as the rear of the car all sound smooth and quiet.
    I drive the car very gently, by the way... I'm not rough with cars at all.
  15. NC_Prius
    NC_Prius Member
    186
    Ok -- I just paid a dealer to check my wheels with the brand new Fuel Max Tires. They heard the noise and said it was definitely a noisy tire. They drove the car, and even ran it again up on the lift. SOOO -- once again I purchased a new set of GY Assurance Fuel Max tires and one was noisy (perhaps defective, but you usually don't know until the belts begin to separate later on). This also proves that not all new tires are quiet -- I've had several of these now that were not.
    As of now, I could not personally recommend purchasing these tires.
    (BTW: It also shows that Discount Tire did not rotate them as claimed).
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thank you for posting about your experience. This is not the first time I've read about a quality concern with this tire. I may make a mention of it in my LRR tire thread.
  17. john1701a
    12,818
    5,303
    58
    Parking without the tire flat on the ground is a common cause of belt separation. I see owners contributing to that all the time, since a majority of the curbs here are angled.
    My set of Fuel-Max tires are still looking fine and are uniformly quiet.
  18. NC_Prius
    NC_Prius Member
    186
    Not here, though. My car is garage-kept, and I park in a large, level parking lot at work. Plus, the tire w/the belt separation was a little noisy from the beginning (like the new one I have now). All I do is commute back and forth, 35 miles each way, on smooth highways at ~65-70mph. The one thing I did neglect was rotating the tires, however, for 24k miles. Still doesn't seem like enough to damage the tire to belt separation under normal circumstances.
    On my first set of tires, one was so noisy I had it immediately replaced. So the one with the eventual belt separation (that wasn't nearly as bad at first) made 2 defective tires that I received from that one set. Now on my second set there is one.
    That said, it seems to be hit-or-miss with many tires. I Googled the Fuel Max and some said it was smooth, quiet and long-lasting while others said it was very noisy and didn't last long. On top of that, I'm sure different factors weigh in: some tires are really better / worse than others, people have different sensitivies and driving habits, and tires ride / wear differently on different vehicles. But in my case, I am *sure* without a doubt that I've gotten 3 less-than-good Fuel Max tires straight off the shelf, so to speak. I guess that's why people say YMMV.
    That said, one tire I saw on the Discount Tire website where everyone unanimously rated it 5 stars (and very quiet) was the Michelin Primacy MXM4. But it doesn't appear to be a low-rolling resistance tire, of course -- realizing LRR tires tend to be a little noisier.
  19. revhigh
    986
    141
    I have had nothing but BAD luck with goodyear tires. Their QC is horrendous. I've been using nothing but Yokohama for the last 8 years or so, and have never had a problem in probably 8-10 sets of tires (3 cars).
    I literally wouldn't put goodyear tires on my car if they were free ... and I mean it. The problems, hassles, and diagnostic costs just aren't worth it.
    REV
  20. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    I have GY Assurance Fuel Max tires (OE), I am coming up on 36K and they are now needing to be replaced. At least before any trip of any distance. I have noticed a wah-wah noise out of them, depending a bit on the road surface. I have run 42/40 pressures in them for most of their life. I wouldn't buy these tires again due them wearing out too soon. I feel I should have gotten at least 50K out of them. They haven't been a bad tire otherwise, were quiet to for at least 20-25K, have held the road good, etc. I think the car deserves better tires for OE than this though.
    I'm presently researching new tires for the car. I do want an LRR tire, and I was really leaning toward Michelin Energy Saver (S8), but they are expensive, and come with only 9/32" of tread. Maybe not a thing to be concerned with, but other tires have 11/32" of tread. I am presently looking at Continental ProContact w/EcoPlus technology. These are LRR tires and priced reasonably, especially on Tire Rack. The reviews on Tire Rack for this tire are maybe 80% good, but the 20% that are not good,.....are bad! Sooooo, what to do??? I would like to buy them locally, but can only "order" them at local tire dealers, and a lot more expensive than Tire Rack.
    Anyway back on subject ---, I did rotate the GY's as they were suppose to be, until this last time, when I forgot about them and I put 9K on them before I knew it. When I did this last rotation I found one which had a 1/2" cut?, or split? in the tread surface. Cross tread, not in grove. I took the car to a GY dealer and he said nothing to worry about, just a cut from our lousy roads!, and he actually found another one the same in another tire while we were talking! He said you can drive them for another "few thousand"....... But I don't think I will even get 40K out of these, unless I'm prepared to stay around home with it. I have no commute,.....I put miles on this car doing trips, and I've no appetite for having tire problems out on the road.
    But regards concerns for the rims, and people not being concerned for someone else's property,......that is exactly right! That's why I "do it myself"! My first two or three services on the car were "complimentary" with the purchase, and I didn't like leaving the car w/o seeing it for someone else to do anything with it! The first oil change they overfilled the crankcase, and I didn't discover it until I had drove it home and let it set for a time! A distance of over 20 miles. So my lack of confidence in anyone else doing anything on my car was only proven to be right.....again.
