Will the Chevrolet Volt be a failure or a success?
Discussion in 'Chevrolet Volt' started by Reginnald, Jan 20, 2011.
  1. mfennell
    mfennell New Member
    241
    39
    200 wh/mi from the battery is 48 miles, which is easily done. From the wall, it's 65 or so, which is high but has been done.
    Wayne at CleanMPG had better numbers in the Volt than the PHV he demo'd. :confused:
  2. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
  3. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    If I were using Volt, I could get fantastic EV range. Infact anyone who lives on a hill can get very good mileage - as long as you don't use EV mode to climb back up ;)
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The full battery is 10.6 kwh if i remember correctly, so 53 miles to not turn GM into liars.
    As if a wayne gerdes drive or a hypermile jaunt somehow excuses the GM hype. You know that the current record for Prius MPG is over 130 mpg, right ? Do you suggest that Toyota use that record to imply that the Prius will consume fuel at that rate for the casual reader of its website ?
    Of course not, so we are left with GM being full of shit, and its fans too clueless for years to realize they were fed baseless hype.
  5. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Link ?
  6. mfennell
    mfennell New Member
    241
    39
    You remember almost correctly. The maximum utilization of the battery is actually 10.4kWh BUT the ICE comes on at about 9.6kWh used (it may be 9.45, I used the higher number).
    You're confusing Wayne's outlier results with "200Wh/mile." 200 is perfectly attainable.
    You sure do get worked up over this. You know it's just a car, right? :p
    Wayne Gerdes seems pretty good at extracting maximum range out of anything he drives. He did better EV (pure EV) in the Volt than the PHV. That's the data. He was surprised too. Spin it as you see fit.
    Thread Here. Wayne finds plenty of things to complain about, which should please everyone. :D
  7. mfennell
    mfennell New Member
    241
    39
    Best I could find was a few references to 250/mi. And SageBrush's post above (Google sure is efficient).
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    EVNow, Dennis' link was awesome. So much for your attempts to rewrite history lol.
    I quote post #47 for posterity:
    In case you missed the posts, energy consumption approaches 500 wh/mile in cold winter months. 250% more than the adverts GM had going for years on their website.
  10. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  12. mfennell
    mfennell New Member
    241
    39
    150% is what you mean.
    The math says 400 wh/mi in cold weather which is 100% though.
    Did you really post that? "voltards?" Is it ok that I imagine you red faced and banging the desk when I read your posts? :D. You sure take it seriously.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    "Voltards" sounds like something from Harry Potter... Or something from a magician's act.
    If you are one of the few that a Volt works for (mostly EV, rarely gas) then awesome. But if you get less combined mileage after converting EV efficiency pre-station to wall to wheels in addition to gas pump to wheels than a Prius, then I would agree with "voltard".
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    Ahh, the joys of translating percentages into english.
    5 *is* 2.5x the number 2.
    lol. No doubt about it, I find GM offensive.
    As for the Volt, I just do not care much about a horribly overpriced poor Prius imitation. On the other hand, there is a nation of worse cars wondering around. Ymmv, as may your opinion.
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It sure is fun reading back their comments. They were so sure GM would deliver what they believed in.
  16. Sergiospl
    3,938
    1,351
    28
    I think it's ok for those who lease the Volt but I would not buy one. I would be afraid that if GM keep losing money on it, they may kill it and I would end up with an orphan vehicle, like a Saturn.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If they fail, I think the Volt may become a collectors vehicle in which case buying makes more sense. It has a lot of the right qualities of a collector vehicle including the quirkiness and flat out stupidity. I for one enjoy "horrible" vehicles as collector vehicles because they are unique and fun. When someone asks "why on earth would they do _______", you can chuckle and tell them "well, that's why they only made X thousand of them".
  18. Trollbait
    12,495
    Are you being misleading?
    Wasn't the Volt in that incident using a charging station, and thus the problem charger would have been stored in the trunk.
  19. mfennell
    mfennell New Member
    241
    39
    Nice. That's the first time I've read that the car will expand pack usage to compensate for battery degradation. Has anyone read that elsewhere?
    I know I'm stunned to hear that numbers they came up with in simulation/with prototype drivetrains didn't make it to production although it is possible to go 40 miles on 8kWh. My average day that doesn't require HVAC is just short of that 200Wh/mi number.
  20. mfennell
    mfennell New Member
    241
    39
    I'll remember this particular quote when Toyota finally releases production specs on the PHV. ;)
