My 2006 Prius Wrecked! :(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mylar, Jun 25, 2011.
  1. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    foyzur,
    If you want your Camry totaled and haven't yet authorized repairs, I would recommend you look into Autoloss.com's Total Loss Report. I originally submitted my DV claim and they advised my car should be totaled but I had already authorized repairs per my insurance companies recommendation. I'm not sure how much a Total Loss Report is but I paid $249 for my DV report. The at fault insurance company in my case is sending an independent appraiser out to look at my car within the next 2 weeks. This is a good sign because it means the insurance company recognizes my claim as valid and they are getting ready to make me a settlement offer.
    As far as my 2006 Prius, I picked it up from the shop on Tuesday. Mechanically the car drives fine, but the Toyota Certified Collision Center lacked the attention to detail I expected them to provide considering they had my car for 37 days and the repairs cost $9400.
    My insurance company wants me to return the car to the shop for additional repairs but I told them all I want is a letter from the body shop stating my car is unable to be brought back to pre-loss condition.
    I will post pics and provide an update once I have ironed out the specifics with my car.
    Thanks for following my post!
    Mylar
  2. foyzur
    foyzur New Member
    Fremont, CA
    Hi Mylar
    Sorry to know that the dealer did not take care of the details. Good luck with your diminished value claim. I hope at least the car will drive flawlessly in the coming days.
    About my side of the story: today my insurance took the car to the shop that I authorized. I already authorized before writing the mail to you :(. The shop just called me and told me there are damage in the package tray area as well, and the insurance simply did not acknowledge that (the initial damage report was made by the insurance adjuster) :( She also told me that the package tray is part of the car's structural part, which got compromised. And there are also some minor roof damage. I am still desperately trying to make the insurance company total the car. I will post update about my situation. BTW, do u have any idea what package tray is? And how important structural part it is of the Car?
    Thanks.
  3. Patrick Wong
    18,200
    6,491
    The package tray runs behind the rear seat back cushion. If that was damaged, then I guess your Camry was hit very hard in the rear.
  4. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    Have the body shop e-mail you a copy of their estimate and forward it to Diminished Value Auto Appraisal Experts | Total Loss Insurance Claims | Wrecked Car Value for you free evaluation. They are experts and help u have you car totaled.
    Mylar
  5. foyzur
    foyzur New Member
    Fremont, CA
    I got an updated estimate today. Now the estimate is 16,097.97. Yet the insurance is vehemently refusing to total the car. I paid autoloss.com to submit a DV claim also. Let's see what happens. thanks for all of your help.
  6. pbui
    pbui Member
    190
    Los Gatos, northern CA
    Foyzur,
    do you have a list of the repaired work ? and part replaced ?
    our 2004 Prius just got wrecked, somewhat similar to yours and Allstate is declaring it total, with the repair cost of at least $14K. The assessor stopped adding once it was over the vehicle value.
    Since there is no liquid leakage; i think it may be just cosmetic. Although the radiator has definitely been moved back a couple of inches. The coolant reservoir may be shot and am thinking of taking it out all together; since the vehicle doesn't really need it for operation. Toyota even did away with the reservoir in later models.
    The Prius front end is kinda of a joke, with the aluminum U-bar bolted on to the soft "frame" members, who are at an angle. It looks like it was really design to bend and give at the slightest bump. Does any one have access to a drawing of how the front end is put together ?
    Thanks in advance..
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The coolant reservoir tech was replaced with exhaust heat recovery tech in the GenIII. Removing it all together wont be a net 0 change.
    The hood area was designed to give on impact, that is the point. Remember back to physics and collisions. If the entire frame was rigid, then you would smash into something and either stop very suddenly or bounce back. By adding things that crush and bend, the car "gradually" slows so it doesn't injure the weakest link in the vehicle (the humans). And the hood area is designed especially to prevent the maiming of pedestrians when they are smucked in a cross-walk which happens more than you may think.
    For drawings on how things go together, I find exploded views helpful. On the online parts catalogues where you select which part you need, generally they are exploded views with the parts numbers.
  8. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    If the vehicle is a total loss I would pay autoloss.com to submit a Total Loss Report which will enable you to get more $$ from the insurance company.
    I paid $15,500 for my fully loaded '06 Prius 15 months ago. I can't touch a similar one for under $25k now.
    If the accident wasn't your fault, the other persons insurance company is required to put you in a similar vehicle so you should get more $$.
    Mylar
  9. pbui
    pbui Member
    190
    the coolant recovery is really meant for speedy warm up right ? am just wondering if the ECU still allow the vehicle to run without it.
    I hear you about the crumper zone, but may be a spring/coil or something; or a design to protect vehicle damage, say up to 5mphr
    Great idea on the parts catalogues exploded view, thanks
  10. pbui
    pbui Member
    190
    My '04 Prius has over 182Kmiles, so they deducted $2K from "market" average and came up with $12.7 K; unfortunately it was driven by my teenager, who was clearly at fault. We're offered $8.6K and keep the wrecked, which is probably what I'll do.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I don't think anyone has tried, however it seems like it is just a relay operated device, so your relay will still click on as if the thermos was supposed to be pumping but nothing.
    To total your car, you were going more than 5mph. There is a "5mph bumper" law actually, surprised you brought it up. A vehicle must be cheap to repair if involved in a low speed (< 5mph) collision on the bumpers. This is why even extremely expensive cars, have very plastic like bumpers.
    A spring or coil wont work at all. It is against physics. Remember that the yield strength of metal is different than the flex strength. If you don't crumple, then the human suffers. If you crumple, you will not ever get back to normal. Plain and simple.
  12. foyzur
    foyzur New Member
    Fremont, CA
    Hi pbui
    State Farm finally decided to total the car. The settlement details isn't here yet. I am attaching the final estimate of repairs (after redacting). I will keep you guys posted.
    BTW, I believe they decided to total the car after I submitted a 9K diminished value report from autoloss.com and along with that I personally wrote a fiery mail (which I also copied to the supervisor of my adjuster). You can also take similar action if you want to total the car. Thanks.
      File size:
      51.2 KB
      480
      File size:
      111.1 KB
      559
      File size:
      83.7 KB
      531
      File size:
      20.2 KB
      499
  13. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    Foyzur,
    You should pay Autoloss.com to write a Total Loss Report. It will allow you to recover more money for your totaled car than the insurance company would normally pay out.
    Mylar
