Bluetooth mic volume
Discussion in 'Gen 3 Prius Technical Discussion' started by citiboi, Aug 7, 2011.
  1. citiboi
    citiboi Junior Member
    Bangkok Thailand
    Hi everyone....
    I am driving a Prius Gen III (without Nav). I have a problem with the sensitivity of the mic whenever I use my BT handsfree to make or receive a call. I have googled as well as searched this forum but have not found any solution to this problem.
    Does anyone know how to adjust the sensitivity of the mic?
    Thanks a million!
    Cheers!
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Edit: sorry--just noticed you don't have nav.
    Here you go:
    [ame="http://www.youtube.com/watch?v=-gwQpvpYVYg"]‪2010 Toyota Prius Bluetooth microphone volume adjustment‬‏ - YouTube[/ame]
    3 people like this.
  3. tchn4life
    tchn4life New Member
    Mississippi
    I had the same problem with my Gen III 2010 without Nav. As long as the air conditioning was off and windows up, I could be heard by callers. In Mississippi in the summer having the air off is not an option. I researched extensively and was told there is no fix. I ended up buying a Parrot bluetooth device. I have a new Gen III 2011 without Nav and have had no problems with the mic volume. Toyota and the dealerships totally deny this has been a problem with anyone.
  4. gliderman
    gliderman Active Member
    751
    225
    Which Parrot bluetooth device did you get?
    Thanks!
  5. citiboi
    Bangkok Thailand
    Thanks for your reply. I read somewhere in this forum that the low sensitivity or bad mic reception may not be Toyota's fault BUT a fault with the cellphone you use. I am using a BlackBerry and understand that BlackBerry's bluetooth connection is not as loud as others.
    Anyway, I am just hoping that someone knows how to increase the sensitivity of the mic in the Prius.
    Thanks anyway. Guess I will just have to try another cellphone.
  6. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    We have a 2011 Model 3. My wife has a Verizon Samsung Fascinate. No problems with talking or listening.
  7. sko580
    sko580 New Member
    Queens, New York City
    Sounds like you maybe getting air crossing into the mic element with AC on and windows open. I have confirmed that I have this issue with AC on high. I dont think these stock mic systems have a very good noise cancellation feature.
    I am going to see what minor mods can be done to avoid air hitting the mic element. Easiest thing is probably putting a piece of clear tape over the microphone area. The other option is opening up the panel assembly where the mic is and sliding a piece of foam in front of the mic.
  8. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    It is not a problem with ur phone.. It is a problem with the mic volume.. I had an Acura tl before with Bluetooth and have the same phone.. Never had problems with volume until I got the prius.. I'm going to try that video since I have navi..
  9. janice45
    janice45 Dudley Girl
    82
    maine
    Toyota is at fault for the low mic senitivity Phones is probably fine .
    They will not and I say will not address this issue .toyota is very much aware .
  10. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    Sensitivity is fine in my 2011 (using iPhone).
  11. citiboi
    Bangkok Thailand
    Update!!
    Apparently, the bad call quality may be due to the cellphone used by the person at the other end.
    I have made many calls using the Prius handsfree since and am glad to report that almost everyone I have called has confirmed that the call quality is superb.
  12. bzyrice
    805
    324
    West Palm
    It is not the cell phone.. I used the EXACT same phone in my old Acura.. It is a lexus/toyota thing.. I tested my phone in her is250, then in my prius.. and my 04 Acurea TL still had better reception.. I tested all of them all in the SAME day.
  13. citiboi
    Bangkok Thailand
    Oh.. YMMV I suppose....
  14. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    80% of the time it the phone. what you may not know is bluetooth is NOT a standard protical (sp?) i may expand on this when not on the train. try google half-duplexing wireless signals.
  15. Davidgr
    Davidgr Junior Member
    Armonk, NY
  16. fotomoto
    fotomoto Senior Member
    5,634
    3,812
    So. Texas
    Unfortunately, no. You can use a scangauge ($160ish) or take it to a dealer who might do it (and the seat belt chime) for free.
