Smart key works on doors, not engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kgagne, Aug 11, 2011.
  1. kgagne
    kgagne Junior Member
    Massachusetts
    Hello,
    I have a 2007 Prius. Last night, my neighbor said he thought he heard my car alarm going off. I used my car fob to turn the alarm on then off to ask him if that's what he'd heard, and it wasn't. Seems he mistook someone else's car for mine.
    Today, I find my car's smart key functionality is limited. I can keep the keys in my pocket and still unlock and lock the doors, but the engine won't turn on, instead displaying the key symbol on the dashboard; I need to insert the fob into the slot instead. None of the buttons (lock, unlock, alarm) on the fob work. The smart key button under the wheel is protruding, as I believe it should.
    Is this just a case of a dying fob battery, or did my test of the alarm last night somehow disable some of my smart key features?
    -Ken
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    With a 2007, if the battery is the original, it is a good chance that it can be the fob battery. They are inexpensive and easy to replace.
    That would be a good place to start.
  3. kgagne
    Massachusetts
    Thanks, JD! Where can I get more information about what kind of battery it is and how to replace it? I don't remember seeing this in the car's manual, though maybe I missed it. I hope something this simple doesn't require a dealer's intervention.
    -Ken
  4. Patrick Wong
    18,200
    6,500
    You need to purchase a CR2032 battery from your local drugstore. You will also need a very tiny Phillips screwdriver, I recall the size is 2 mm. I suggest you replace the batteries on all fobs that you have for the car.
    The instructions to replace the fob battery should be in the owner's manual and you can also search on PriusChat for many posts about how to do this. This does require some strength from the thumb on your hand to successfully slide the fob cover off.
  5. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
  6. kgagne
    Massachusetts
    Thanks, all! The simple process of replacing my fob's battery appears to have cured what ailed me.
