Best spot for a booster seat?
Discussion in 'Gen 2 Prius Main Forum' started by delrey, May 1, 2004.
  1. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    Anyone else have a booster and the ability to put it in any position?
    If so, where do you think the best spot is?
    Middle seems good from the kid's point of view -- good visibility through the front, and is supposed to be the safest. Also nice if I'm driving folks for lunch (yes, I'll be volunteering to drive whenever I have a chance!!!)
    Side seems better for the seat being the most stable, at least for our booster seat. Also the height of the seat back seems to block my rear visibility a bit more in the middle than I think it will on the side.
    Thoughts?
  2. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    We prefer the middle, for safety's sake.
    Our daughter likes to see the screen (especially with NAV in operation) and she can see forward better. She likes that as well.
    In the middle, there is less kicking of the front seats.
    The only problem I see is that the seat belt binds sometimes because the return slot is shaped in a T pattern, and the belt sometimes gets stuck in the base of the T.
  3. Raenstoirm
    Raenstoirm New Member
    179
    Maryland
    Also be careful of covering that vent. The last thing you want to do is overheat your battery!
