what's the air box for ?
Discussion in 'Gen 2 Prius Technical Discussion' started by pbui, Aug 21, 2011.
  1. pbui
    pbui Member
    190
    Los Gatos, northern CA
    My teenager crunched our 2004, among a number of damaged items is a white box behind the right fender, connecting to the air filter intake hose. It looks like a bee nest (there is a dead butterfly in there too). It must be some sort of air baffle, does any one know its purpose ? does the Prius need it to operate properly ? is it just for intake noise reduction like an exhaust muffler ?
    Tx
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    In addition to noise reduction, IIRC, it also
    * helps remove water from intake air
    * it is part of a "tuned" length, designed for max efficiency.
    Rather than buying a new one you should consider getting a salvaged one.
    AutoBeYours is a Prius specific salvage yard/rebuilder. They enjoy an
    excellent reputation here for low cost, reliability, and quick service.
  3. tf4624
    tf4624 Active Member
    527
    51
    Lol it's a wast of plastic and oil. I have removed mine
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    On a Prius?
    What does it sound like compared to a normal 4 cylinder engine with the airbox removed?
  5. pbui
    pbui Member
    190
    I am starting to think it acts like a capacitor in a circuit, to smooth out the in rush demand, thus lower effective impedance (EE 101 all over again). If my guess is correct, then it does help with the in-flow, ever so slightly.
    I did check with autobeyours, thanks for the suggestion.
  6. qbee42
    3,079
    This is what Rokeby meant when he referred to the the tuned length. It does indeed act like a capacitor.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I thought it was just to store some spare air in case it runs out. :p
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Unfortunately for performance it also acts like a resistor.
    It's there to tune out noise and even the airflow over the rpm range, at some sacrifice of peak airflow.
  9. qbee42
    3,079
    Which isn't an issue with the Prius, since the ICE is limited to well below peak power.
