Got schooled today on Prius plastics
Discussion in 'Gen 3 Prius Main Forum' started by oldasdust, Sep 3, 2011.
  1. oldasdust
    oldasdust Member
    356
    47
    illinois
    I had a passenger today in my 2011 Gen III who has over a decade in the plastic industry for a top global petrochemical corporation. I told them many people complain about the cheap plastic in the prius Gen III that marks easily. They started laughing and advised thin plastics used in conserving weight have to be more impact resistant and softer to avoid breaking and therefore cost more than thicker and harder plastics used most other vehicle applications. That followed with their so don't call this interior cheap. Boy did i get schooled. The process of using recycled plastics for a savings came up to was advised an ecological savings but very marginal cost savings of those plastics. Gee i was o for 2 LOL by the way they had never rode in a Gen III before and liked the car, so i scored 1 point for having a nice car.
    2 people like this.
    50,826
    and they are vegetable based, are they not?
  3. oldasdust
    oldasdust Member
    356
    47
    illinois
    All the plastics used in the interior are vegtable based? Has that technology been released for mass production products and if so when ?
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    They are referring to the plastic used in the Lexus, not in the Prius.
  5. El Dobro
    El Dobro A Member
    7,071
    3,258
    Vegetable based? Wow, that's like having your car and eating it too. :p
    3 people like this.
  6. RRxing
    RRxing Senior Member
    2,528
    1,803
    NEPA
  7. oldasdust
    oldasdust Member
    356
    47
    illinois
    From what i have been told vegtable based plastics are quite new and at this time are more costly than petroleum based plastics. When they become mass produced and accepted the price will come down and may replace many petroleum based plastics. Lots of testing is being conducted. Anyone know how much of the lexus interior is vegtable based plastics? intersting to say the least.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    So an expert sat in the OP's car and can't recognize the plastic he was talking about?
    Yeah, so little of it is used, but I find them really difficult to clean, particularly the light gray cowl side trim.
  9. oldasdust
    oldasdust Member
    356
    47
    illinois
    I did not type every word or conversation with what you called an expert in my vehicle but they knew it was a poly olefin. How can you tell which one easy they said looking over my shoulder while i'm typing destroy it. Burn the plastic the smoke color and smell will tell you which poly olefin is present. How did this turn into this just posted thin plastic expensive and soft thus marks easily news to me schooled is all.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I just want to say one word to you. Just one word.
    Yes, sir.
    Are you listening?
    Yes, I am.
    Plastics.
    Exactly how do you mean?
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I've had most of the plastic out of the front of my GenIII doing different mods and it's easy to tell what type of plastic each piece is. Just about all of it is marked on the back, that's a much cheaper way to tell what it is than setting it on fire:D
    Most of it is either marked PP/PE with is PolyEthylene/PolyPropylene. They are both polyolefins. Several pieces in the center counsel and some other pieces are ABS/PC which is Acrylonitrile Butadiene Styrene/Polycarbonate. The door panels are also PP/PE.
  12. oldasdust
    oldasdust Member
    356
    47
    illinois
    Thanks for the info about stampings on back so is it like they said somewhat more $$ because thin and soft thus incorrect to call the interior cheap a word many have used to describe the Gen III interior partly because it is easily marred.
  13. Tideland Prius
    16,408
    As RRxing posted, the some parts are plant-based (and why only the driver's seat and not both front seat foam is beyond me). Toyota developed their own Toyota Super Olefin plastic that's highly recyclable.
    As for Lexus, well the HS's seat padding is made out of kenaf fibres and castor seeds per the brochure.
  14. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    So now you can have your seat and eat it too. Or plant it if you prefer.
  15. El Dobro
    El Dobro A Member
    7,071
    3,258
    It may have something to do with the passenger presence sensor.
  16. RRxing
    2,528
    1,803
    NEPA
    I was also curious as to why only the driver's seat cushion was plant-based and not any of the other seats. Now I'm wondering if this seat cushion played any part in the front bottom edge of my leather driver's seat becoming detached and had to be replaced. They replaced both the seat cushion (pad) and the seat bottom leather. Curiouser and curiouser...
  17. oldasdust
    oldasdust Member
    356
    47
    illinois
    A piece here and there of plant based plastics. They are being tested and evaluated with new ones invented replacing petrroleum based here and there. One day all will probably be plant based,mass marketed and mass produced. Those plastics will be used extensively for food storage and containers. We have bio diesel can they make bio gasoline ?
  18. Tideland Prius
    16,408
    And good places to test them too. They're out of the way but they're also areas that will most likely get scuffed.
    Maybe it's because it's the most used seat? Or maybe the padding is different between the driver's and passenger's seat.
    good point. Maybe the density of the foam couldn't be achieved to get the sensor to work properly.
    Where's my corn-based plastic pen? :D
  19. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Not so. Gen III Prius plastics are vegetable based too!
  20. El Dobro
    El Dobro A Member
    7,071
    3,258
    I recommend salad dressing over ArmorAll for interior cleaning.
