TSB for front brake caliper rattle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, Sep 14, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    I've seen a couple threads about this issue. A service bulletin was published today. Toyota has finally owned up and redesigned the caliper slide pin bushing. Well, they almost owned up, as free replacement is under 3/36 warranty. See attached pdf
  2. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Great, thanks again...off to the dealer I go with the TSBs for the frontal calipers, the rear squeak and the oil change door. I am just not sure they will honor it since my door hasn't fallen off yet (though it is looking a little worn/torn in one spot). I also question the rear break squeak since that does not happen consistently, and they might try to weasel their way out of the repair.
  3. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Thanks for posting the TSB. However, looks like it's not much more than grease job to waste my time at dealer. :(
  4. seilerts
    3,326
    1,519
    Santa Fe, NM
    I agree, unless you are at the dealer for scheduled maintenance, it is not worth the trip. But I think every 2010 will get bushings, not just a grease job.
  5. Canard
    Canard Member
    223
    Ontario, Canada
    Great find on the TSB - Thank you, thank you, thank you!
    -Iain
  6. Analogkid1958
    Analogkid1958 Member
    119
    61
    Yorktown, IN
    2024 Prius
    My car's way out of warranty - I'm assuming I can get the new parts whenever I get the pads changed - whenever that happens (85,000 miles and they're still at 75%!)?
  7. johnmaci
    johnmaci Junior Member
    30
    MD
    Merci!
    I had been looking for something like this for a while, but could not find it.
    I think a link to this TSB should be posted on the Prius Chat homepage for all to see :rockon:
