Out Of Alignment From Factory?
Discussion in 'Gen 3 Prius Main Forum' started by The Critic, Sep 27, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I was shopping at Sears tonight and noticed they had a new Hunter Hawkeye alignment system installed. So, I had them do an alignment check for me as I had suspected that my Prius had been out-of-alignment from the beginning due to its handling.
    Sure enough....
    The LF toe is at -0.12 and the RF toe is at -0.08, iirc. I'm guessing that the preferred setting for front toe is about 0.10, which is a slight amount of toe-in.
    Though the alignment is not terribly off, it's definitely off enough to explain why my steering wheel is just a hair off to the right and the car has never felt completely stable on the highway. Perhaps this may also explain why my fuel economy is a bit below average-- though it has improved a little lately to 46-47 ever since I reached 8,000 miles.
    I had bought a Firestone lifetime alignment a while ago when it was on sale, so I'll probably just take the car there to have it aligned. However, does anyone know if Toyota offers a 1/12k adjustment period? If they'll cover the alignment under that policy, that'd save me a trip to Firestone since I'll be at the dealer for a 10k service this Sat.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    On mine, a alignment check was offered in the first year. Whether this would include a free alignment or not is open to question. Ask dealer.
  3. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    The Critic,
    It looks like you've been around here for a while (since 2005), so I thought you might have seen some of the older posts about alignments on the 2G Priuses. Their adjustment period back then was for 12 months or 20,000 miles (I believe), but I think you had to complain about poor handling first to get Toyota to do an actual alignment (NOT just a check).
    I think Toyota paid for some parts to be replaced too, but I'm not sure to what extent. Some rear ends were out of spec & the only way to supposedly correct that was to replace the entire rear axle, but unless you had the alignment checked immediately after delivery, I think Toyota fought against having to replace the axle on their dime---they thought the owners hit something hard. (You could do a search here to find some of those old posts to find out what the outcomes of some of the posters were). There were also some recommendations of toe amounts to set to, to help avoid the tendency to drift or wander in the wind.
    Some of the problem, I believe, was due to the way some of the truckers lashed the cars down onto the car transport trucks (I think they were bending some suspension components by hooking onto the wrong things & cranking them down too tight). So, as long as you're under the 12 months/20,000 miles (if that's the same limits for the 3rd generation too), I would visit the dealer first for your alignment & ask them to bring your steering wheel back to center/level (& verify it gets done before you leave).
    Your handling should improve after the alignment, but one poster (either here or over at PriusOnLine.com) didn't resolve his poor handling issues until his dealer did an entire steering re-calibration [with a number of specs (that he listed) being re-set]. Look for that post while doing your search (& post a link to it, please, if you find it) & print it out for your future reference. Good luck !!!
    Ken (in Bolton,Ct)
  4. The Critic
    3,193
    2,333
    CA
    Thanks. I just got off the phone with my advisor and he said it's definitely a possibility if it can be demonstrated that it was an issue from the factory. If there's any doubt of Toyota covering it, I'll just take it to Firestone since I have an active lifetime alignment policy with them.
  5. The Critic
    3,193
    2,333
    CA
    I haven't decided this yet, but I may decide to install two camber bolts in the front in order to fine tune the camber adjustments. The camber is acceptable as-is, but the amount of cross camber is not ideal.
  6. mickey513
    mickey513 Member
    127
    Cali
    Toyota does offer 1 year, 20k miles on the alignment the first year. I thought it was 12k miles but the warranty pamphlet that comes with the car say it's 1 year, 20k miles.
    My 2011 was also "out of spec" from the dealership that I purchased it from, brand new earlier in the year. At first I thought it was "all in my head" because it was a brand new car but the steering wheel was crooked to the right a little bit. Had them inspect and adjust the alignment free of charge during the first 5k miles.
  7. txl146
    txl146 Member
    301
    NY
    The Critic,
    Is there a limit on number of times you can get your car aligned at the Firestone? in other words, can you take your car in for an alignment once a month?
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    My front-end alignment from the factory was slightly off in toe-in, but I don't recall exactly how much. Found this out after having the alignment checked after my Tanabe spring install, which didn't change the camber at all. That's usually what suffers with lowering springs. The springs wouldn't affect toe-in.
  9. The Critic
    3,193
    2,333
    CA
    That's odd because lowering springs will affect camber and a change in camber has a huge effect on toe.
    MB860 ?
  10. The Critic
    3,193
    2,333
    CA
    There is no limit on the number of alignments per year.
    MB860 ?
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    My Gen2 Prius was delivered with a bent rear axle beam. I suspect it happened during shipment, cars are sometimes treated brutally during loading and unloading.
    The dealer replaced the axle beam, unfortunately the new one was further out, in the other direction, than the original. They wouldn't replace it a second time because they said it was within the specification, just barely. But without enough toe in the rear the car would not go down the road in a straight line.
    Fortunately one of the posters on this site was a very good Prius Technician. He was kind enough to send me a pattern for shims that would change the rear toe without changing the camber. I fabricated and installed shims of the proper thickness. With the rear toe toward the center of its range and the front toed in slightly, still within the spec, the car was fine.
    My present Gen3 Prius has none of those problems and is very stable on the highway. Since it drives great and the tires are wearing evenly I haven't had the alignment checked and probably won't.
  12. Dark_matter_doesn't
    692
    151
    Seattle, WA
    The camber may not be affected if the drop is moderate. I lowered my Integra with a Tokico kit less than 2", and I put in a camber adjustment kit. Turned out it wasn't really needed when I had the suspension alignment checked.
  13. The Critic
    3,193
    2,333
    CA
    RF toe was out, but LF toe was not.
    Camber was fine.
    Car handles much better now, but they left the steering wheel slightly off-center to the right. So back to the dealer tomorrow...another 1 hr drive.
