Battery question.
Discussion in 'Gen 3 Prius Technical Discussion' started by Caug1, Sep 29, 2011.
  1. Caug1
    Caug1 Member
    119
    BOSTON
    Hello,
    is it normal that over night parking battery looses charge from 7 bars down to 2 bars?
    I never lock the car and leaving my key in it.
    Thanks,
    c
  2. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I never know what is normal any more. But my strong suspicion is the fault lies in "leaving my keys in it." I suspect the keys are maintaing systems in a ready to go status. When I walk into the garage, I hear systems beginning to activate just because of the presence of the keys in close proximity.
    An easy fix. Don't leave the keys tonight and see what it looks like in the morning.
    BTW, on my G3, I see no reduction in charge overnight. I have left it up to two weeks with do obvious discharge (realistically, there is some, but it is not noticable).
    Good luck.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The HV battery is disconnected when the car is OFF. Leaving the key in the car will cause a drain of the 12V battery as Felt points out by keeping the SKS system active, among others.
    When you first start the car in the morning the HV battery will be charging the 12 V battery while the ICE is warming up. This could drop the HV battery SOC.
    Also changes in temp will show a change in SOC when the computers recalculate the SOC in the morning.
    Is the change is SOC as soon as you power up in the morning or shortly after?
    I rarely see much of a change in SOC in the mornings even after a few days of not driving.
  4. Caug1
    Caug1 Member
    119
    BOSTON
    When i turn the car on this morning, it was 2 bars right away.
    it's not always with 2 bar deal.
    some times it mid way, but key is always in it.
    c
  5. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    sure you're turning the car off at night?
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Am what is the temperature range? Does it go from really hot to really cold over night?
    Are you 100% sure you correctly turn the car off correctly and if so is the car definitely at 5 bars before switch off and then only 2 bars immediately upon switching on again?
    If this is the case then you might have a HV battery issue. At least worth getting it checked by your dealers for peace of mind.
  7. Caug1
    Caug1 Member
    119
    BOSTON
    I am sure , i turn the car off.
    The temp. drops to to low 60 from hi 60 at night.
    The car doesn't do it often, just some times.
    car was full charge , nut the last bar. i never had it with all the bars full.
    turn in am and only 2 were lit up.
    but car works good no problem at all. it goes down to 2 bar only in i am in stop and go traffic some times.
    c
  8. qbee42
    3,080
    As pointed out above, the HV battery is disconnected when the Prius is powered off. There is no load which can drain the battery.
    Battery State of Charge (SoC) is calculated, as there is no way to physically measure levels as you do with a gas tank. Temperature and other factors influence SoC calculations, so it is possible to "lose" bars even when the charge remains the same.
    Most people complaining about losing bars overnight are actually complaining about bars quickly dropping in the morning. They are not the same. SoC normally drops quickly in the morning, when the Prius is started with a cold engine, where the Prius relies heavily on electric for the first few minutes.
    Dropping bars in stop and go traffic is normal. The Prius is minimizing the use of the engine.
  9. Caug1
    Caug1 Member
    119
    BOSTON
    Thanks man.
    i feel better.
    car is fine period.
    i just noticed this thing and figured to ask all of you.
    Thanks,
    C
  10. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Is your last leg home mostly with the ICE off?
    I've found my car goes into EV mode the last 1/3 mile so the battery is usually pretty low when I go to start the car in the morning. It quickly charges upon breaking and coasting the next day.
  11. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Dum-de-dum-DUMB
