Rear Spoiler Used to Close Hatchback
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrnoyb, Oct 1, 2011.
  1. mrnoyb
    mrnoyb Junior Member
    52
    NA
    deleted
  2. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I would imagine if you push down towards the front end of the spoiler, you'd be OK. I wouldn't recommend pushing on the overhang part, as it seems a little loose(?) to begin with. I just give a good tug on the inside handle and it'll close the hatch each time. Otherwise, you could just push on bottom part of the "trunk" where the license plate is.
  3. bisco
    51,032
    i use the inside handle to pull it down and the emblem to push it shut. i think the spoiler is a touch and go situation, although i have used it in a hurry, just to continue the momentum and letting off just as it closed.
  4. ETC(SS)
    6,917
    I tend not to use mine because it's black and will show every little scratch. I close it as the previous poster has pointed out, by puching down on the hatch near the rear license plate.
    The rear spoiler is pretty fragile, but IMHO it shouldn't crack or come off the car by just closing the rear hatch.
    YMMV.
    Good Luck!
  5. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I try to use the lip below the license plate to hold on to with my fingers to close the hatch. I try to use my finger tips and not dig my nails into it.
    That being said, if you move the whole assembly slowly, you are not likely to damage the spoiler.
    People try to swing it down hard because there is quite a bit of resistance. At least that's my experience based on the way my air springs were set at the factory.
  6. Tideland Prius
    16,431
    Use the emblem.
    I found it easier to close the Gen 3's hatch since it tends to close on its own about 3/4 of the way down (so 1/4 til close)
  7. Mendel Leisk
    40,481
    Once in a while I use the spoiler to finish the job, and just make a point of pushing at the edge closest to the front of the car, where it's more solidly connected (per Wick1ert).
    (I pulled of our hatch interior panels one time and removed the spoiler to have a look. Snugged the bolts down a bit better when re-installing. The difference is noticeable: there's less wiggle now.)
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Bingo... a person shouldn't have to pull it down past 3/4 too 1/2 the way because it will close itself very nicely after half way. Just a little patience is needed.
  9. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    The best advice on the rear spoiler is not to touch it ever...
    OK, very gently when washing/waxing, with a hand supporting
    it from below. Otherwise, never, nunca, jamais. ;)
    It is really just a plastic add-on held on with a few clips, just hanging
    out in the breeze, not meant to be subjected to any kind of up-and-
    down or sideways loads.
    Once looseneed/cracked or broken, tigtening/replacing it involves
    taking all the interior bits off the hatch... a whole lot of agrivation.
    Some threads from folks who have learned the hard way:
    http://priuschat.com/forums/gen-iii...ance-troubleshooting/81372-loose-spoiler.html
    http://priuschat.com/forums/gen-iii...363-gen-iii-spoiler-removal-w-photos-how.html
    http://priuschat.com/forums/gen-iii...-need-help-broke-2010-prius-rear-spoiler.html
  10. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    pull it form inside, let it go, it will close easy enough on it's own. It shoudln't need a push, like trunks used to.
  11. xamnosidda
    xamnosidda Junior Member
    61
    Celebration, FL
    Speaking of the rear spoiler, do you guys wax yours? I did this last time and to me it appears that waxing it is just fine.
  12. Timw
    Timw Junior Member
    55
    Southern, PA
    As far as using the spoiler, if you read your owners manual it specifically says not to use the spoiler to close the back hatch. And Yes I wax it every time I wax the car.
  13. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I just bought a trunk license handle/finger lip for the hatch.
    I hate the grimey finger prints on the hatch every time I close it.
    I know there are pull downs in the door but it's a habit to use the hatch door from the outside.
    The part goes behind the license plate and uses the two screws on the bottom of the plate.
    I will let you know if it works well when I get my plates on the new 2011.
  14. mrnoyb
    52
    NA
  15. mrnoyb
    52
    NA
  16. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Keep using the small grip holes inside...once you get used to it....it will become much easier....
  17. Timw
    Timw Junior Member
    55
    Southern, PA
    I know I read it, I'll have to check.
  18. Tideland Prius
    16,431
    Yeah I wax mine and it's super shiny after that. There are still fine scratches though (from me washing/drying the car but barely noticeable and it's holding up much better than what MB used on the smart. That shiny black plastic 'faded" and scratched as soon as I hand washed it)
  19. johalareewi
    johalareewi Member
    393
    44
    uk
    I read it my manual too.
    BTW I use the pull down hard on the internal handle and let it drop technique. Works every time and I don't get dirty fingers :)
  20. Timw
    Timw Junior Member
    55
    Southern, PA
    My Bad! Just looked at the manual again and I saw something I thought was the spoiler but that wasn't it! OOPS!
