Door, hood, trunk rubber weather strip protection
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rrg, Oct 4, 2011.
  1. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    One of the first things I did beside washing was to use rubber protection on all rubber trim door, hood gaskets. The car sits outside. No usable garage.
    In northern NJ I have friends who always complain about frozen doors in winter. When I use Gummi Pfledge rubber protection the doors never stick or dry out over time and the rubber stays elastic. My old car with 210,000 never had a problem outside. The only problem I notice is that it does attract dust easy. The BMW guys really love this stuff on the forum I found it on.
    By the way the skinny rubber strip between the lower hatch glass and the car body seemed very gray and dry (take a look) until I applied this stuff. Now it's black and soft again.
    Oh by the way I also use 303 protectant but this stuff last longer for outside IMO.
    Clay bar and waxing is next as soon as the weather gets above 50deg.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I used Einszett Gummi Pfledge on the door seals of my last car (BMW 545i) to alleviate a well-know squeaking issue on those cars.
    303 Protectant is also great--have used it on tire sidewalls and other exterior rubber for a long time.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    +1 on the 303 and it can be used for other applications around the house too. I have a new front door made of some type of plastic that has the appearance of wood in both color and grain. I use 303 to protect it from direct afternoon sun.
  4. Mendel Leisk
    41,379
    One thing to do periodically with the gasket around the hatch opening: starting at the top/centre, pull it up and off the lip (it's just attached by friction) and have a look under. If you get any amount of rain you'll likely find some slimey grunge under there.
  5. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
  6. Mendel Leisk
    41,379
    ^ You're making my response sound kinda clinical too, LOL.
  7. RoyThePriusGuy
    186
    25
    phoenix
    I was gonna rsp re yours too - but this is a G-rated site.
    Well most times anyway...
