Defrost and Climate Control
Discussion in 'Gen 2 Prius Main Forum' started by tripp, Nov 29, 2005.
  1. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Howdy all,
    On the way back from a hockey game tonight I had to run the defrost several times to clear the front windshield. I noticed that everytime I turned on the front defrost the climate control kicked in and stayed on even after I shut off the defrost. I didn't really need the bloody climate control on so I had to keep turning it off, which is a pain in the arse. Is there a way to have the climate control turn off when I toggle off the front defrost?
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    If you just leave the climate control on you won't have to worry about defrosting your windshield.
  3. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    There is also a vent selection that gets you defrost without kicking in the big front defrost.
  4. jimgraffam
    jimgraffam New Member
    131
    Sterling, MA
    I like to control my fan speed manually. If you have manual fan speed on and auto a/c off, you can turn the front defrost on/off at your convenience without re-engaging auto a/c. I've also become accustomed to turning off the heat altogether for the first 5 minutes or so... especially in stop 'n' go driving.
  5. jeromep
    jeromep Member
    827
    Eastern Washington State
    The smartest thing said by any infomercial host was Ron Popiel. "Set it and forget it."
    The Prius A/C system is not automatic for your benefit so much as it is automatic for the car's benefit. The auto a/c system was designed to keep you comfortable, but it was also designed to keep the battery comfortable. In other words, if you keep your cabin between 68 and 80 degrees the battery operates much more efficiently than if it is operating at very cold or very hot temperatures. The battery uses cabin air for heat dissipation, but during the winter it also uses cabin heat to help get the battery up to a more efficient operating temperature. If you are choosing to turn off the a/c system altogether or are keeping low fan when the system would run high fan, you might be hindering the vehicles ability to provide the car with the most efficient battery operating temperature.
  6. MNPrius
    MNPrius New Member
    177
    Minneapolis
    Hockey! My favorite sport. Thanks for the reminder that I can put on the front defrost from the steering wheel. I'm interested in finding an answer ...although what I am looking for is a way to adjust the level of air flow from the A/C system without having to go to climate control screen. I'm not a MPG at all costs, I will be comfortable in my car :)
  7. deh2k
    deh2k New Member
    241
    New Hampshire
    I don't know why it does that. But I have found that a click of the Auto A/C button on the steering wheel will stop the defroster, so a double-click on that button will shut defrost and Auto A/C off.
  8. ABC12
    ABC12 New Member
    45
    yea, but it shuts the whole environmental system, not just ac
  9. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Unless I'm uncomfortable, I do turn the whole thing off in the morning lately to avoid running the ICE more than I need. With no breeze at all, sometimes I think a jacket is too warm at 42. Recirculate mode helps cut down on any breeze...
  10. KTPhil
    KTPhil Active Member
    1,379
    22
    GO KINGS!
  11. tripp
    4,717
    79
    Denver, CO
    Thanks for all of the input fellas. I'm sure I'll put it to good use soon. As for me, I'm definitely in the MPG at all cost camp. And after a game the last thing that I really need is a warm cabin. I just wanna be able to see the bleedin' road.
  12. MNPrius
    MNPrius New Member
    177
    Minneapolis
    So -- I'm assuming here that you are PLAYING the game instead of just watching it?! 'because then, cold is better!!! :blink: (speaks someone who routinely rides with 3 hockey players at various ages in life)
