E85 fuel
Discussion in 'Gen 2 Prius Accessories & Modifications' started by drew_flux, Oct 8, 2011.
  1. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    Anyone blending E85 in their prius? with the way fuel price's are here in Australia, im thinking about blending fuel to 15% E as a start off point. I think the stock ecu maybe able to run up to 20%. From there ill start looking at bigger injectors/fuel pump. what are your thoughts ?
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    In the US, I can't get E85 for 30% cheaper than E10, and since I am going to get at least 30% poorer fuel mileage, I am losing money if E85 is not 30% cheaper.
    The Prius is not designed to run on E85 in the US.
    If you do not have those stumbling blocks down under, go for it.
    http://alternativefuels.about.com/od/ethanol/a/E85economydrop.htm
  3. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    E15 is more of a political issue than a technical one. There's an upcoming mandate for that in Minnesota. Studies of E20 are helping to confirm that E15 won't be a big deal.
    The point is millions upon millions of vehicles running E15 would have a profoundly larger impact than the vehicles capable of E85 which rarely (if ever) actually use it.
    Running E85 in a stock Prius isn't good. You'll eventually trigger some sensor errors, since the system hasn't been calibrated to use it. E15 would be fine though.
  4. drew_flux
    73
    22
    sydney australia
    well my car is now on E20. will see where we end up after a full tank. i now have yaris 1.8L injectors sitting here also.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Let us know how ur Prius likes it.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    You will definitely get lean burn DTCs if you run E85. I think your only option is to get a higher volume injector. I am not aware of any way to modify the ECM to increase injector pulse length.
  7. drew_flux
    73
    22
    sydney australia
    it can be done two ways. piggyback ecu or signal modification of the maf. or bigger injectors/fuel system mods. i have 3sets of injectors on hand ready for testing.
    suprise for the day .1 long term fuel trim has droped (think my injectors were blocked more than i thought) .2 no more pinging on realy big hills. .3 put the borescope in the tank, nothing floating around yet... famous last words? time will tell. .4using less throttle on freeway to maintain 110kph cruse .5no dtc's yet
    my goals for this exercise are. cheap fuel,clean enging internals, cause im bored and can lol.
    next tank going for 50% E by volume.
    just remember AU spec vehicles have different tanks/ filters to US spec vehicles. no blader tank to eat up. As a fyi tuned a r34 skyline today afterhours. my nice person dyno is feeling +50 hp on a direct swap to E85.real dyno tomorrow with pfc ecu. i think we will hit closer to +100hp after puting more time in the calibration
  8. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    Drew, where are you getting e85 from in Sydney? know of anywhere near the Hills that sells it?
  9. seilerts
    3,326
    1,518
    Santa Fe, NM
    What was your before and after LT fuel trim? What are the RONs of the gas and the E85? Is the E85 RON higher than the highest premium gas in Australia? We have had reports here of people that need to run 89 or 91 AKI (93 - 95 RON) to avoid knock in high mileage engines (100,000+ miles)
    Anyway, it is rare to see tuners here, so please do keep us updated on your progress! Given that E85 has 75% of the energy density by volume compared to gas, you will run into a problem eventually. I think your custom E50 blend will work, however -- and you should see your fuel trim running significantly positive at that point. That would be a good time to put in the next size up injectors. Ideally, you have an injector that runs somewhat positive LT trim with E85 and somewhat negative LT trim on gas but still falls with +/- 20% to avoid rich or lean DTCs. Beyond that, you're looking at electronic modification.
  10. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    majority of US have mandatory 10% in our regular; and in some midwest stations which also sell E85 it is more like 20-30%, cheaters
    I remember reading a few years back (~2005-6) Toyota tested several models (primarily Camry) and found no problems. At 20% they experienced ~3% MPG drop, perhaps due to less energy content.
  11. drew_flux
    73
    22
    sydney australia
    im buying at united@roseberry and from caltex@ morebank. for you pendle hill caltex is the closest i know of. be careful though. united is on summer mix @90%E on my tester kit. caltex came in at 78% (think they were still runing winter mix). i bought my test kits from rocket mailorder.
  12. drew_flux
    73
    22
    sydney australia
    Australian fuel is junk, when compaired to what you guys have.the octane rating here is in RON not MON. our grades are 91 ron with10%E,95 then 98ron. our 98 is chemicaly close to US 91mon and our 91 ron if you can find it is closer to US 87ish area.
    you can buy a race fuel version of E85 by the drum, but its not cheap.its made from 98ron then blended.
    Q1 yes E85 is highest graded fuel you can get from the pump.
    Q2 at the start of the tank LTFT was sitting on +18% with no dtc logged. at 1/4 tank of E20 its now +14%. i did put some injector cleaner in the tank though.the injectors may come out for cleaning/swaping soon.
    one of the reasons why i did this to a prius is: the engine has a high static commpression ratio at 13to1. this helps you not lose as much power due to the lower energy content of E85. the atkinson cycle operation also make me want to turbocharge the engine.
    Justdidit and seilerts like this.
  13. Prius1222
    Prius1222 New Member
    Dortmund, Germany
    Hey, i am Chris from Germany and i have done 1875 km on E85. What brings me to an acceptable 39.2 MPG rating. I am using an E85 conversion kit.
    Using E85 i am acutally saving 1,20 € per 100km.
    Regular Gas: 1,60/litre
    Ethanol: 1,12/litre
    Malko30 likes this.
  14. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    Interesting and welcome. That would be about $7.80/gal for gasoline and $5.50/gal for E85. Presumably the tax policy accounts for part of the cost difference. What is the source of the ethanol? Import or made in Germany?
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    DO it! :) They had to with the Hydrogen Prius because the power output was lowered so much...turbo brought it back almost to where it should have been running on 87.
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    You have any experience doing so? Only documentation of this was done on the G1 during a turbo install. Ran into all sorts of issues...but it WAS possible with success.
  17. wjtracy
    11,363
    3,607
    Northern VA (NoVA)
    ^^^note this is really old thread we just tacked onto
  18. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Yes, I'm awfully good/bad at reviving old threads...just this time it wasn't me. :)
  19. Prius1222
    Dortmund, Germany
    The fuel ist made in Germany from corn, potatoes or sugar beets. And yes, it's the tax that's making all the difference. You can image why nobody is driving an F150 or a Tundra here. You are getting poor by starting the engine. So don't worry about your gas prices.
    I have some pictures from the installation of the so called "ecobox E85" (about $220).
    Ground for the box and my Daytime running light:
    Fuel Injectors:
    Throttle damper:
    The box has a sensor that monitors the temperature. If the engine is to cold (e.g. cold winter), it enriches the fuel automatically as much as you have set before (e.g. 40%). The sensor is installed between the water pump and the engine with aluminium foil.
    You can deactivate the box with the little switch on the left. If you are using Regular Gas.
    The box. Now i have fixed it better.
    And the software (in german):
    You can set:
    Enrichment during engine start under 57 degrees. I have set 60%
    Enrichment during engine warmup. I have acutally set 35% for 2 minutes. The engine must be colder than 75 degrees.
    And finally enrichment while the engine is running. I have acutally set 30%.
    While driving about 75 mph straight i have an LTF of 4.5. While climbing hills on the motorway or going 100mph, it can go up to 8 - 11.
    wjtracy and Justdidit like this.
  20. ive
    ive Member
    104
    43
    I run the same box here in Germany about 10000 miles now, runs fine winter (freezing temps, snow etc.) and summer (+37°C so far). Milage drops by 265 (winter) to 30% (summer) depending on the seasonal blend. In winter, e85 in northern Europe only contains 65% Ethanol to help cold starting according to the fuel norm.
    With the above shown enrichment, the are no starting problems. It sounds pretty much like with petrol, just a tad muter. In winter, your car's tail pipe may smell from cheap booze for the first minute.
    The car runs nice and strong. Drove up a reasonably steep long hill last week with an indicated 180km/h w/ cruise control on the Autobahn and the battery was continued to be charged.
    You do only need some 80% of throttle to maintain top speed right below speed limiter. My car indicated 181 or 182km/h on the limiter.
    Without a piggy back, you are restricted to about 70% Ethanol in summer and about 40% winter before the ECU throws a code. With the piggy back ECU you can run straight e85 throughout the year.
    If you run low on e85, just fill it up with normal petrol and flip a switch to deactivate the piggy back ECU.
    Next time you refill with e85, flip the switch back and off you go. Open hood, flip switch, check oil and refill wiper fluid as your are there anyhow, close hood, go.
    As long as you do not add more than about a quarter of petrol to the e85, you can leave the piggy back activated.
    The Prius will adapt in short oder. This way you may add some 5-10 liter of petrol to half a tank of e85 to get you to your next e85-station.
    Marko
    wjtracy likes this.
