Rear fog lights...?
Discussion in 'Gen 2 Prius Main Forum' started by pearsonrj, Nov 29, 2005.
  1. pearsonrj
    pearsonrj Junior Member
    64
    Concord, CA
    2015 Prius Plug-in
    From the UK Toyota website it looks like the Prius comes with rear fog lights. Do ALL European Prii come with them, or do they only come with the more expensive packages? Are the US Prius taillight housings designed to accomodate a rear fog light? Where is the on/off switch on European Prii? Is there a kit that can be bought here in the US or in Europe to fit a rear fog light using the existing taillight housing?
    Thanks!
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
  3. KMO
    KMO Senior Member
    1,891
    645
    Finland
    2023 Prius Prime
    The switch is in the same place as that for the front fog lamps. If you have front fog lamps, they come on as the first stop on the twist-ring, and then turning it further activates the rear fog lamps (and the ring springs back).
    The US taillight housing differs in two ways (that I can see) from European ones. Firstly, it has an extra strip of red reflector up the side, and secondly the tail light is twice the size, occupying the combined space of the European fog lamp and tail lamp. The European fog lamp is inboard of the tail lamp.
  4. pearsonrj
    64
    Concord, CA
    2015 Prius Plug-in
    Thanks for the answers. Personally I think rear fog lamps should be required in the US. Most manufacturers seem to favor front fog lamps over rears, mainly because car buyers think they make the car look better and provide better visibility in all low light conditions (which I think is rubbish). Rear fog lamps may save you from being rear-ended in fog, whereas if you don't have front fog lamps then you just have to drive a little bit slower...
  5. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    I've only noticed the fog in front of the car.
