DIY Transmission Fluid Change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dcoyne78, Dec 2, 2009.
  1. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    With their comment about a torque converter, I suspect they aren't dialed in on Prius transmissions.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    Here is the reply I received from Blackstone:
    "Tom,
    Thanks for the email. The reason your unit location averages changed is because they are driven off the equipment type and we had your transaxle logged in twice under the same make/model. The problem is that history is driven off of the unit ID and those didn't match up. If you're thoroughly confused, don't worry because it's now been fixed. Thanks for some of the technical specs. We'll be sure not to say that aluminum is from the torque converter in the future. We do have a special equipment ID just for a Prius transaxle so I put on note on our system to use that as opposed to just a standard Toyota automatic. Thanks again for the email. I'll amend the report and send it email it out this afternoon.
    Alex Miller
    Blackstone Laboratories
    PS--We're always learning new things from our customers. If you have any idea where that aluminum is coming from, I'd love to share the information with the other analysts. We have quite a bit of knowledge here, but we also value the input from our enthusiast customers."
    Here is the revised oil analysis report, note they recommended a 20K change due the aluminum:
  3. veggieranger
    veggieranger Junior Member
    37
    Peachtree City, GA
    I'm pretty new to the site and just bought a 2004 Prius in September. After searching and reading the site, I've made a list of services I'm going to perform on the Prius since it has 130k miles on it.
    I just finished the transmission fluid change this afternoon and thought I would share some pics and results. My mileage was 132k miles and from the service history I'm pretty certain the fluid has never been changed.
    Here are some pics of the fluid and the drain and fill plugs:
    drain plug after removing from CVT:
    Drain and fill plugs after cleaning:
    Used fluid compared to new fluid:
    Tools I used for the job:
    Funnel and plastic tubing for refilling the CVT:
    Jacking up the rear of the Prius (front wheels were on ramps):
    Leveling the Prius before filling:
    Overall, this job took less than an hour including the time to make the transmission fluid bong. It's definitely a two person job for the refill.
    -VR
  4. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    The wear does appear quite high from tumbleweed's two UOA reports. The aluminum in the second sample seems unusually high; I wonder if that is the normal wear pattern for this transaxle.
    I plan to change the fluid on mine at 15k, and possibly add some BG CVT Fluid Conditioner to it. This product is supposed to boost the anti-wear capabilities of CVT fluids. I will e-mail BG to ask them if it is suitable for use in our cars.
    http://www.kansasbg.com/Complete_Set_of_Spec_and_Tech/0302.pdf
    BG Products, Inc.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The Prius CVT doesn't have any of the mechanical elements in it that cause CVT lubrication difficulties.
  6. The Critic
    3,193
    2,330
    CA
    Assuming this page is correct...
    Toyota Prius - Power Split Device
    I would think that the planetary gear set will need a lubricant that has adequate anti-wear performance.
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Unlike the planetary gear sets in a regular automatic. It doesn't have to deal with crud in the oil from wearing clutches. It has an easy life.
  8. Mendel Leisk
    41,020
    That's basically what I did, except at 15,000 kilometers. Already it was looking quite murky.
    Just my 2 cents: stick with just the Toyota ATF-WS fluid. Regardless of what they say, or how safe it actually is, just not worth the potential risk.
  9. Den49
    Den49 Member
    498
    272
    Maryland
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    At $85 it will pay for itself compared to a dealer trans oil change in less than 2 changes. Looks like a toy I might need.
  11. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    DEN - I'd be interested in how it works out for you. If you're on the eastern part of MD, maybe I can borrow it when I do mine? I'm just over 27k miles, and figure at the next oil change next year, it'll be time to do the trans fluid.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
  14. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    And if you don't have your ATF fluid yet, I actually bought mine on eBay too: 4quarts for $23.99 + shipping. Came to ~$30 total with UPS ground. Better than local dealerships even before tax.
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Best I could find on eBay was $42.20 with shipping.:mad: Do you remember where you got yours?
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Indeed he has. Bummer.
    Well I would still buy it. Having it shipped to my door versus me having to drive somewhere during "business hours" which I despise is something I am willing to pay more for. And even so, it is still less with the new price and shipping than the MSRP at the dealership + sales tax not including my time going down there and explaining I don't want the service, just the little bottles of fluid.
  19. wheelsup
    wheelsup Junior Member
    97
    Raleigh, NC
    arun2633 likes this.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Well it is $12.99 normally + tax intown which would make it cheaper or $12.99 + shipping which would make it just as expensive.
    That store is nowhere close to me geographically, so I would have to ship it. Good find though if you are in their region, especially with the sales price.
