Tire Pressure Monitoring System and Cold Weather
Discussion in 'Gen 3 Prius Main Forum' started by zyx345, Nov 4, 2011.
  1. zyx345
    zyx345 Junior Member
    42
    Northern, NJ
    For some reason, my TPMS warning light has been going on in the morning when its really cold out in the North East, and then later in the day its no longer on.
    Does cold weather affect the TPMS?
    Could it be that my tires are just on the borderline of tripping off the warning?
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Cold weather affects the tire pressure, as I recall: 1 lb/10 degF
    It could be that you need to check your tire pressure.
  3. jrb451
    jrb451 Junior Member
    59
    Conway, AR
    "Yes" to both questions.
  4. Mendel Leisk
    41,020
    I've heard the pressure needs to drop about 25% from the set* pressure, before you get a warning. Just to get the obvious out of the way: have you checked the pressures?
    * You can reset that level, explanation in Owners Manual, on page 443, albeit somewhat confusing:
    The "few minutes" in step 5 confuses me: 5, 10, 15 minutes? I did this once, think I used 10 minutes.
    The reset button is under the dash in vicinity of steering wheel: says "SET" and has a flat tire with exclamation symbol.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The attached TSB on TPMS Initialization specifies a minimum of 5 minutes. I was not sure about the few minutes. I used 3 minutes (few) when I increased my tire pressure and it appeared to work properly. I may have to go back and hold it for 5 minutes to make sure :rolleyes:
  6. Mendel Leisk
    41,020
    Thanks for that!
    A suggestion I've read, keeping in mind the possible 25% pressure drop needed to trigger the alarm, is to overinflate, say 15%, reinitialize the TPMS, and then reduce pressures to your normal. So that the TPMS is on more of a hair-trigger.
    I've not bothered with it though: my set pressure is maybe 25% over spec. to begin with, so as long as it were to trigger when I went a bit below spec. that would be fine with me.
  7. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I thought about this and came to the same conclusion you did. I just had a screw in a front tire, and I was keeping the fronts at 40 lbs. and when the TPMS light came on, I checked the pressure and it was down to 30 lbs, and that was plenty of air to still drive on it. Visually, the tire looked the same as the other tires.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I had the very same issue as you with a screw in the tire. Same tire pressures and alarm points. I came to the same conclusion, also.
  9. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I don't know about the 1 psi per 10 deg F rule. I think it drops more than that. It will drop even faster if the temperature drops below the freezing point (most of the water vapour in the tire will freeze out to "snow").
    I checked Pearl's tires about a month ago and found them at 38 PSI average, and they started at 40 PSI average a month before when the new Nokian WRGIIs were installed (yes, I run the fronts 2 PSI higher than the rears). I put in 44 PSI in the front and 42 PSI in the rear, anticipating further dropping. The temperature when the tires were installed was around 15C and a month ago it was around 10C. It's now around 0C. Heading for -20C in another month (DON'T RUSH IT!!). ;)
    It's not the TPMS working incorrectly, it's the temperature causing the pressure to drop. The TPMS is just warning you to CHECK YOUR TIRES!!! PLEASE CHECK YOUR TIRES!!!
    We don't want any "Ford style" exploding tires on Prius! We have enough problems with idiots claiming failures in other systems already. ;)
  10. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Your tire pressure is inadequate. Set the tire pressures at the lowest ambient temperature that the car will be operated in and this won't become an issue.
    MB860 ?
  11. Jasonsprite
    Jasonsprite Junior Member
    74
    Northridge(Los Angeles),Ca
    2019 Prius Prime
    i live in los angeles. took the car up to the mountains once there the TPM came on . i checked tire presssure and the tires .everything was ok. once i came down the mountain the TPM light went off. some times on cool days when i start the car in the morning the TPM comes on. Now its on all the time. tire place said everuthings ok with the tires and not sure why the TPM light is on.im waiting till i get some time to got o the Dealer to have them check it out.
  12. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    When you turn on the car, does the light blink for about a minute, then stay solid? Or does it just come on solid from when you start the car? If it's blinking for 60 seconds then staying solid, you'll probably need to take it into the dealer. If the light just comes on solid from the start, try resetting the pressures with the reset button. It could be that they were set the last time when the pressures were high and you just didn't know.
  13. 06COMMUTER
    06COMMUTER Junior Member
    26
    Is there a reset button for the 2006? If so, I can't find it. I hate taking it to the dealer for everything!
  14. bisco
    51,574
    not sure, did u check the o/m? might be under the steering wheel beneath the dash.
  15. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    515
    Outside Philly, PA
    The TPMS transponders each have a battery. This is not a normal service item (TPMS "service" at tire changes apparently amounts to an o-ring replacement). Anyone out there know when the batteries start to die (and need replacement)? I'm guessing a decade might be about it.
    (This, of course, assumes you have checked your tire pressures and used the reset button as described in the manual and you still have the trouble light.)
  16. David Beale
    5,963
    1,988
    Edmonton Alberta
    The TPMS "set" button is on the bottom of the dash close to the steering wheel. Put your head on the floor and look up. You put the proper pressure in the tyres, then press and hold that button until it responds (with a beep as I recall). I don't remember if the car has to be in "ready" or not.
    You cannot replace the batteries in the sensors. You have to replace the sensors. Then you have to get the dealer to enter the new sensors into the TPMS system with the Toyota Tech tool. The sensors are not cheap, and neither is the dealer service! ;) The sensors go -inside- the tyre (one bead must be "broken"), and the valve stems you see on the outside are part of the sensor.
  17. Mendel Leisk
    41,020
    I search through a pdf of 2006 Owners Manual (all I happened to have); didn't see anything. FWIW, our previous car was a Canadian 2006 model year (a Honda) and did not have any TPMS. I don't think Toyota would implement it unless they had to by regulation. Just Googling, I believe it became mandatory in new vehicles, at least in the 'States, as of Sept 01, 2007:
    Federal Motor Vehicle Safety Standards; TPMS; Controls and Displays. Final Rule.
  18. Mendel Leisk
    41,020
    In the 'States you legally "have" to. In Canada, while new vehicles all have some sort of TPMS, from reading on Transport Canada website I don't believe it's mandatory to replace them if they fail, or if you acquire separate snow tires on rims:
    Ask TC Road Safety - Transport Canada
  19. ILuvMyPriusToo
    778
    515
    Outside Philly, PA
    On my 2009, you do this in "Ready" and hold the button in until the yellow warning light flashes on/off three times on the dash.
  20. Hannah Andersen
    Hannah Andersen Junior Member
    Dallas/Ft. Worth
    2022 Prius
    My tire pressure warning light flickered on as soon as the temperatures dropped so quickly into the 30s. A few days later of the cold temps and it came on and stayed on. I thought it would go back to normal when the temperatures got back to normal but, no. So I checked the pressure. It had dropped from 35 to 20! I got myself to the tire pressure thing at the gas station and all is well now.
