I had forgotten to turn it off
Discussion in 'Prius v Main Forum' started by parnami, Nov 16, 2011.
  1. parnami
    parnami Member
    227
    48
    .Lancaster, PA (Amish Country) :)
    I finally test drove a v yesterday and was quite pleased. The controls seemed pretty intuitive, good ride, switching from electric to gas power seamless. Everything was great! It was only after I got home that I remembered I hadn't turned it off when I got out. This could be a problem!
    My question: is there a backup procedure that turns the car off if you forget? For instance, if I get out and lock the doors, is the car smart enough to know it shouldn't be running? Living in Philly, I never forget to lock the doors to my cars. I do fear I'll leave it running making it an easy target for philadelphians to "borrow".:confused:
  2. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    The car will not let you lock it if it is still "running". It will give you three loud beeps no matter if you try to use the door switch, the door handle, or the remote.
    In over one year of ownership, I've left mine on once. I parked at loud, busy street festival and couldn't hear it warning me as I walked away chasing one of my excited kids. Came back about an hour later to find it had burned about a PIP's worth of gas with lights, a/c, and stereo all on. :doh:Luckily, I live in a pretty safe area.
  3. qbee42
    3,079
    All Prius automatically turn off when they run out of gas.
