LEDs?
Discussion in 'Gen 3 Prius Technical Discussion' started by Bazil, Oct 21, 2011.
  1. Bazil
    Bazil New Member
    44
    Erina N.S.W. Australia
    I
    I notice what appear to be six small LEDs in each headlight, between the parking light and main headlights, never seen any illumination from them so are they just decoration or do some countries get DRLs. I notice the Lexus CT200H has DRLs and it's the same car under the tin...I think. Anyone help?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    They are not led's, they are there for aesthetics.
    EVO 4G ?.
  3. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    It is just a decoration or the rest from the designer's table, never used in production. Toyota decided not use it for DRL, as the 2011 has a special reflectors for DRL in place where are fog lamps currently.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It would have looked good if they were LED's but they're not and were not used in any market.
    There are after market kits available in Japan that have replaced them with proper LED's and they look good. Being Japanese they'll be RHD so depending on local restrictions you may be able to legally use them in Oz.
  5. Bazil
    Bazil New Member
    44
    I
    Thanks Grumpy, I think I gotta have these, even contemplated drilling them out and poking LEDs in there.
    Hmmmm, Yorkshire eh? if it's so good why did a certain sea captn, name a Cook, take off and discover Australia?
    Just jokin,been there and done all the touristy things. That Shambles looks like it needs a bit of work!
  6. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
    I saw somewhere on PChat - he baked off headlamps, drilled 5 high luminiscent LEDs and glued them back. No feedback about the potential humidity problems or so. I would not do this before end of warranty (if anytime at all). The headlamp assembly is quite expensive toy and we don't have a suitable secondary market here for the replacement.
  7. Bazil
    Bazil New Member
    44
    I
    Agreed.
  8. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    Mine turns on. There is a button on the bottom right of the steering wheel!!
    JK
    Here is a pic of mine. Yes the headlight had to be taken apart. One apart I thought I would add a few other led's.
    2 people like this.
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Nice job! +1
  10. Bazil
    Bazil New Member
    44
    I
    Wish I hadn't seen that, man, that is so cool!!!!!
  11. KK6PD
    4,003
    946
    118
    I think that a bit of patience and some skills could duplicate this look. I like how the color temps match. Nice detail! :D
  12. lpe350
    lpe350 Member
    56
    32
    Long Island
    Nice! I've been thinking about doing the 5 leds but like others have said, I'm afraid to disassemble the light also.
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Very nice. Can you share your LED source and the part #'s you used?
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    Disassembly is quite easy. The hard part is putting the lens back on without getting adhesive on the inside shiny parts. :D
