Anyone Have a Rattle in their Tail Light?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by car compulsive, Nov 19, 2011.
  1. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I've had this intermittent plastic rattle coming from the back end on bumpy roads at low speed. It's not the license plate and bracket (already fixed that one). Yesterday I happened to tap on the outside of my left tail light and heard it rattle with the same noise I'm hearing on the inside of the car. There is no rattle when I tap on the right tail light. Has anyone else experienced or cured this? I figure I'll ask the dealer to investigate at the 5K service visit which should be about Christmas.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    If the rattle is easily duplicated, let your dealership fix it. Are you sure it's not the spoiler or license plate?
  3. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    I've got a rattle but I'm pretty sure it's the spoiler, it seems very loose on the right side , are all the spoilers like this???
  4. phoenixgreg
    1,157
    295
    66
    Phoenix
    Some here have complained about a loose spoiler. Mine made a clicking sound if you would wiggle it up and down. I solved it by carefully embedding some foam rubber underneath the spoiler where it meets the small rear window. But a precaution; the mounts are not that good on the spoiler as some have reported breakages. Maybe your dealer could tighten it for you - if you still have some warranty.
  5. car compulsive
    741
    274
    Michigan
    Not the spoiler, definitely the left tail light lens. I'll see what the dealer says.
  6. EthanC
    EthanC Junior Member
    17
    SF bay
    Please let us know how it goes. I have noise coming from left rear hatch area that I cannot figure out what causes it. It seems to be similar to yours.
    I have dealer replace my rear break system but still hear that noise.
    Thanks
    Ethan
