Oil filters
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wheelsup, Nov 26, 2011.
  1. wheelsup
    wheelsup Junior Member
    91
    Raleigh, NC
    What brand / where to acquire oil filters? For my Volvo I buy a case of 12 for about $5/pop from a Euro car site, what is a good source for our 2010 Prius? Looking for quality too not the cheapie Fram stuff.
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    What kind of oil filter Toyota, where to get them at a dealership parts counter or online.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You can get OEM Toyota filters for about $3.60 - $4.00 on most sites... just google in Toyota parts.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    trdsparks.com is a good place to get them from. Order a few other items too so the shipping will be worth it. Or check ebay.
  5. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I picked up 3 of them at the dealer for about $8 each when it was time to do my first oil change at 5k miles (before they changed the interval). I'm sure they're cheaper now.
    Other options are WIX filters, which you can find at AMSOIL or other sites, too. I put the WIX in at this last oil change, so we'll see if it seems to make any difference when I get the oil analysis done.
    The other options listed above are also good places.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I just get an oil filter, drain plug washer and 4 quarts of 0W-20 oil from my dealer when ready to change. Their price is competitive with the auto parts stores.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    As previously stated there are a lot of Toyota parts available online. I ordered a case of 10 Toyota filters $45 and 10 drain plug washer $12 from Toyota of Dallas. Filter comes with a new O-ring for the filter cap.
    Some part numbers for filters:
    Toyota 04152-YZZA6
    NAPA 7064
    WIX 57064
    Toyota drain plug washer 90430-12031
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    Santa Fe, NM
    O'Reilleys carries Wix. Carquest Blue and Napa filters are also made by Wix. You can also get Wix by the 12 ct. case online for around $5.50 each shipped. That said, Toyota OEM filters are better than average and it's hard to go wrong on both quality and price. Fram used to make good filters but now they are crap.
    This is a pretty good deal on ebay, a 10 filter case with drain plug gaskets for $43:
    Genuine 04152-YZZA6 with Drain Plug Gaskets (Qty 10) | eBay
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Do the non Toyota filters come with the o-ring for the filter housing?
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I know the Fram do, I suspect the others should as well or there would be a serious problem. ;)
  11. wheelsup
    91
    Raleigh, NC
    Thanks guys I might just get them from Toyota. I know for my Volvo the blue boxed branded stuff is made by Mann which is 3x as expensive as if you buy it from Mann online. Looks like Toyota I guess has their own filters made to spec for their private brand? Anyone know if there is an OEM for them?
    Skibob likes this.
  12. wick1ert
    1,311
    183
    Delawhere
    WIX does as well. I would imagine, though, that the O-Rings would last for 2 oil changes if someone was stuck having to re-use it.
  13. The Critic
    3,193
    2,327
    CA
    Not sure, but the genuine filters are so cheap that it is unlikely for the supplier's aftermarket version to be cheaper.
    The supplier to the OEM may sell the part under their brand but the part is not always the same.
  14. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    yes
  15. Mendel Leisk
    40,472
    What I do, everytime I need an oil change, fwiw:
    Go to dealership, buy 4 liters of Toyota 0W20 motor oil, the drain plug washer and a single Toyota oil filter.
  16. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
  17. wheelsup
    91
    Raleigh, NC
    Just called my local dealer. They sell 3 oil filters for $13.xx. It's around 4.50 per filter vs. $5.40 normal price. That's about as cheap as they come. Volvo blue box is around $15 vs. $5 for the Mann, which is why I was asking. So Toyota OEM it is. The crush washers are around $1 so I will take one to Home Depot and get an aluminum or brass one of the correct size for around $0.20.
  18. The Critic
    3,193
    2,327
    CA
    Just saw this listing on ebay:
    100PC Toyota Oil Drain Plug Crush Washer Gaskets 90430-12031 | eBay
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There is nothing special about aluminum crush washers. Find a generic one the right diameter and close to the right thickness and you are good to go at for below dealer prices. A good auto parts store will carry them
  20. wheelsup
    91
    Raleigh, NC
