Complete Racing Overhaul
Discussion in 'Gen 2 Prius Accessories & Modifications' started by walamoonbeam, Nov 22, 2011.
  1. walamoonbeam
    walamoonbeam New Member
    Saratoga
    First off, I don't want to step on any toes, as I know there are a lot of people who dislike the idea of using a Prius as a base for a performance car. But just HYPOTHETICALLY, if I were to desire to pretty much make my Gen 2 2007 Prius a track ready car, what specific parts/mods would you do to it?
    Things I've currently thought of are replace the front seats with sparco seats, and replace the rear seats with a 6 point roll cage. And I was also thinking 17" wheels with a wider track, using stickier tires, and some sort of suspension upgrade, but I have no idea what kind of suspension parts would be best.
    As this is half speculation, and only half serious pretend as though there are no price limitations :)
  2. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    you'd also need a real engine..not a 100hp electric go kart motor :rolleyes:
    Buy an Evo or STi and call it a day
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    The car can handle pretty well with the right suspension mods but like LIPriusFreak stated, the major limitation is HP and the unpredictability of the HV battery being charged or not which dictates how much power you have.
    Mods for handling:
    Lowering springs or coilovers
    New struts
    17"-18" wheels
    Rear sway bar
    Front sway bar (may induce too much understear)
    Strut tower brace
    Undercarriage brace (Tanabe)
    Good sticky tires
    The only problem is while the car will stick like glue to corners, you will be in a race prep class which will pit you against higher HP cars or ones that naturally handle better *cough* Miata and Jetta.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    Santa Fe, NM
    Remove all hybrid components and install Redtop BEAMS. Everything about this car is completely inadequate for the track, except for the drag coefficient, so plan on stripping it to the shell and working your way back up. Might start with a burned one from Copart auctions, instead of taking apart a good one.
  6. sidecar
    sidecar Member
    342
    44
    Australia
    absolutely require coilovers for their capacity for adjustment
    if you are going to run 17" wheels look at bigger brakes,
    and compare available competition equipment for Corolla, Scion and other models
    running just a Prius body might be a good thing as far as attention getting and how that appeals to advertisers, but the aluminium parts wont be as repairable so you need glass panels just about all round, its a Prius in name only, but that isnt a bad thing ..
  7. walamoonbeam
    Saratoga
    Yeah, and also there are issues with the traction control system intervening all the time. But again I'm mostly just speculating. Thanks for the list!
  8. walamoonbeam
    Saratoga
    Ahahahahaha, yeah that is actually why I started thinking about this. I went to a company the other day for a sponsorship presentation, trying to get sponsorships for our robotics team, and one of the execs had an STI that he got the suspension tuned on (no engine upgrades, just handling), with sparco bucket seats, racing harnesses, and a roll cage in the back. I jokingly asked him if I could have a ride, and then he unlocked his car and then he told me to hop in. It was a fun 3 minutes. The presentation we did wasn't as exciting. Or loud.
    I know the Prius won't be quite the same thing, but I like the idea that it can be a sheep in wolf's clothing. Plus I figure it would be really unique to see a Prius with racing seats and a roll cage :p
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
  10. LIPriusFreak
    449
    34
    Long Island, NY
    yeah the STi is DEFINITELY an interesting ride...my friend has an 07 STi with about 600whp running 30psi of boost...took me for a few rides...needless to say 120mph in an STi is an experience....a nauseating one but an experience nonetheless :lol:
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I got a ride in a modified STI with an excellent track driver. The STI had about the the same power to weight ratio as my C6 corvette. 3 laps around Thunderhill Raceway in Northern California. 3 miles and 15 turns per lap of Nirvana.
  12. a_gray_prius
    2,927
    783
    IL
    At 600hp, 120mph is what, a 30 second ride?
    OP: copy these guys
    http://priuschat.com/forums/gen-ii-prius-main-forum/16285-prius-scca-solo-ii-fsp.html
  13. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Buy a Corvette, then mould a modified Prius body to fit. :D
  14. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  15. walamoonbeam
    Saratoga
    That's exactly what I was looking for! Ahaha that's so cool. Can't find any information on the ECU mods unfortunately. It would be cool to get a little more power. But whatever. I'm mainly interested in handling upgrades. Do you know of they are still racing with it?
  16. a_gray_prius
    2,927
    783
    IL
    I have no idea if you're still racing it. You might want to try and track them down - they don't seem to be active around here anymore.
  17. LIPriusFreak
    449
    34
    Long Island, NY
    not even...he hit 120 in just about a 1/4 mile....probably 11 seconds
    felt like an hour tho...the G forces were so intense and he doesn't have 3 point belts, just stand STi belts with the 2010 Suede STi seats
  18. F8L
    19,011
    4,083
    Grass Valley, CA.
    120mph is good for a low 11sec or high 10sec 1/4mile depending on the 60' time. :) I went 122mph on an 11.2 1/4mile with a 1.7 60' time. The nitrous was acting up though so the 60' was kind of high. It is normally 1.5 when N/A.
  19. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Jack up the Prius radiator cap, and drive a new car underneath.
  20. MarvinHC
    MarvinHC Junior Member
    49
    Europe
