SmartKey Buttons Not Working
Discussion in 'Gen 2 Prius Main Forum' started by jeffhobbs, Dec 4, 2011.
  1. jeffhobbs
    jeffhobbs New Member
    Gonzales, CA
    I've got a 2007 Prius and the buttons on one of the smart keys no longer works. With the key in hand, I can touch the door handle and the door will unlock. I can also turn the car on without placing the SKS in the slot. However the lock/unlock/emergency buttons don't work. Everything works fine on my other SKS so I don't believe it's something with the car. I've also checked the KEY button below the steering wheel - it's out.
    I've just changed the batteries on the broken SKS. Even going as far as pulling the battery out of the completely functional SKS and putting it into the broken SKS. Still, the three buttons don't work.
    Any thoughts on how to remedy?
    Thanks in advance!
    Jeff
  2. Tideland Prius
    16,547
    So it's probably the circuit board on the faulty remote, then? Have you check the soldering to see if something is amiss?
  3. jeffhobbs
    Gonzales, CA
    No I haven't. I wanted to make sure I wasn't missing something else before trying to tear apart the remote. Is taking apart the fob to see the circuitry documented on the forum somewhere? I've changed the battery a number of times, so I can get to that level without a problem. Is there some way (besides breaking it) to see the circuitry?
    Thanks!
    Jeff
  4. Tideland Prius
    16,547
    It's been a while since I've opened a Gen 2 fob. On the Gen 3 the battery is behind the circuit board so it's exposed and one can examine it without any tools.
