BP: Halliburton destroyed key oil spill evidence
Discussion in 'Environmental Discussion' started by cyclopathic, Dec 6, 2011.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    BP: Halliburton destroyed key oil spill evidence - CBS News
  2. milkman44
    milkman44 Active Member
    591
    386
    Ky
    No surprises here..:rolleyes:
  3. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Shocked, I tell ya!
  4. oldasdust
    oldasdust Member
    356
    47
    illinois
    They are masters at covering their tracks, they leave no trace they were there poof.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Who would have thunk Halliburton would do something unethical. Shocking, simply shocking.
  6. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Of course BP could have checked the cement out for themselves. But no, let's overlook it until we get into trouble and then say it is all Halliburton's fault.....
  7. cyclopathic
    3,292
    547
    2014 Prius c
    why did they have to? do you run a hairdryer you got in Walmart through all kinds of tests to make sure it will not cause fire?
  8. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    If the Chinese Manufacturer of the hairdryer applied to UL for a testing and approval of that hairdryer, then YES. Sadly you would be hard pressed to find anything electric from China with a UL Label!
  10. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    No, but when dealing with industrial operations that can kill many and cause billions in damage AND losses, most other oil companies do those checks. (P.S. Much earlier threads made it quite evident that BP had lower QA standards, so this really was a continuation of that, not a blind comment.)
  11. cyclopathic
    3,292
    547
    2014 Prius c
    there is also a big question of what the federal/state inspectors were doing, why didn't they catch it??
  12. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    We know that BP abandoned safety protocols and is the main reason this disaster happened. That doesn't mean that transocean, haliburton, and MMS do not share in the blame. If BP did the right things the disaster would have never happened. If MMS had not allowed BP to do the wrong things the disaster might not have happened. Haliburton and transocean also did some things very wrong, but I doubt if they had acted properly the spill would have been avoided.
    Halliburton shares fall after BP accusations - BusinessWeek
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Could destruction of evidence, either wilful or accidental, be considered contempt of court?
    I wonder which will last longer: The environmental damage, or the litigation?
  14. austingreen
    13,671
    4,209
    Austin, TX, USA
    Destruction of evidence if its material is a bigger charge than contempt of court. From the reporting, I don't think this "evidence" was material to a criminal case, or even to the awards of a civil case. The court had already decided from other evidence that Halliburton had not used proper cement. The destruction of evidence is really more about a pissing match with finger pointing between the 3 corporations responsible. BP says that haliburton is more responsible, haliburton says every one knew about the cement for a long time, bp had full access to the tests and is still the company that rolled back safety standards in a rush to drill so that the well would cost less. This pissing match is quite apart from the reforms needed in MMS to do things like make sure drillers don't just throw away safety standards and use inferior materials.
  15. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Which was more or less my cynical point, that more time and money will be expended on assigning blame, than will be spent on cleaning up the spill, or enacting safer standards.
  16. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    It's amazing how, in business, it's better not to check something, so then you can blame it on someone else when it goes bad. At least, that's how it might go in court.
  17. El Dobro
    El Dobro A Member
    7,086
    3,263
    This is like Bonnie saying Clyde robbed banks.
  18. cyclopathic
    3,292
    547
    2014 Prius c
    well if BP new they would have had the test results/models they say Hlaiburton destroyed, wouldn't they?
    I am more concern that all this passed through federal inspections with flying colors. Perhaps DOI was too busy blowing bribes they got from HB on blow and hookers (err oil industry PR representatives).
    Sex, Drug Use and Graft Cited in Interior Department - NYTimes.com
  19. austingreen
    13,671
    4,209
    Austin, TX, USA
    no. bp wants some data that makes haliburton look worse. They do have the data that the cement was not up to standards. That is not enough for them to get money from haliburton and shift blame.
    BP and Halliburton knew of Gulf oil well cement flaws | Environment | guardian.co.uk
    BP wants haliburton's internal test, and want to ignore their own test, which causes doubt that both the cement was at fault, and that BP actually poured cement when their own tests did not show it to be up to industry standards.
    The department of MMS is inside interior. One of the first orders of business of the interior was supposed to be reforming MMS where these problems were known. AFAIK MMS is partially responsible since it approved all the shortcuts to safety that BP asked for some without even reading the documents.
  20. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    The best I can figure, they were nowhere around....so as not to get any dirty oil on their cheerleading suits.
