Does the PIP have a pre-heater ?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kithmo, Nov 22, 2011.
  1. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    Before I spent money on an electric blanket, I would check out the heated front seats to see if that heat was adequate. Also, I'd want to know how much power the blanket draws before I would invest in one. The order page says nothing about the blanket power draw.
    51,937
    likewise!;)
  3. bisco
    51,937
    sweet! when my wife and i were datting in 1977, i was driving a TR-4 with no floorboards and no heat. i had that same blanket in the car (without the electric) for her when i picked her up for a date. i got it from the bank when i opened a savings account. i'm still not sure why she married me.:rolleyes:
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I found something similar and it says 6.7 amp power draw.
  5. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yeah I found a range from 4 amps to the 6.7 amps you noted. Weird the 48 Watts ones were higher rated than the 81 Watt one. May be the quality of the blanket.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Heated seats, electric blankets etc. are all well and good for keeping the occupants of the car warm, but that would not be my concern, I can wear more clothing.
    What I would see as more useful would be the facility to keep the windows clear of ice and mist and that would be the main reason I'd want a pre-heater for winter.
  7. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    The problem with pre-heating in humid climates is that the windows fog up - requiring us to run heater to defog. I guess better than having to scrape the windows if you park outside.
  8. bisco
    51,937
    hmmm, never thought of that. could be a dealbreaker.
  9. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    A dealbreaker for the Leaf???
  10. Trollbait
    12,539
    I have some control with the HHR's remote start by presetting the HVAC controls. The rear defroster automatically comes on in the cold.
    I'm surprised these EVs and PHVs aren't more sophisticated in their preconditioning.
  11. bisco
    51,937
    no, for the pip. i'm wondering now if i'm going to have to run the defroster a lot which is going to make the engine come on. i seem to produce a lot of steam singing in the car.:redface:
  12. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Ofcourse, there is a way in which to "run" defrost in Leaf by opening the vents to fresh air but not turning on the heater. This makes the car cold more quickly - but not for the first 4 or 5 miles.
  13. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    With all that hot air, the windows should defrost, already!
    Seriously, this exchange is splitting hairs. It takes several minutes to defrost (defog). If the trip is several minutes long we can safely run the ICE and warm the car. If the trip is just a couple of minutes long, it is better to keep the car cold and the windows clear.
    My neighbor had his car stolen this morning. He left it running to warm it up and someone just drove it away.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    We get that over here in the UK, it's known as frost jacking, people leaving their cars running to defrost the windows.
    Most UK insurance companies won't pay out if the car is stolen with the keys in.
  15. bisco
    51,937
    what if the car is stolen, but the fob is in your pocket?:eek:
  16. iRun26.2
    824
    169
    United States
    What would happen to a Prius if you drove off and left the fob behind (once it was started)? Could you go 100's of miles if you just didn't turn it off? (sorry, off topic question)
  17. bisco
    51,937
    i thought if you left it running, and walked away with the fob, you were s.o.o.l.?
  18. macman408
    1,179
    367
    Oh yes it will! It'll beep at you (inside and out) and put up a warning message on the MFD, but the car will go as far as you want it to without the fob until it is turned off. Good thing, too - it'd be a pain if your fob battery died and it wouldn't shift!
    If you want more info on this, it's been discussed ad infinitum many times before... A quick search should turn up a few results.
  19. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Gen 2 will drive w/o the Fob too.
  20. iRun26.2
    824
    169
    United States
    Will the PiP have a 'fob slot'?
