Oil change crush washer?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lenjack, Mar 20, 2007.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I will be doing my first oil change on my '07. Does the prius use a crushwasher? What's the best place to get them. Use new one at each change?
  2. John in LB
    John in LB Life is good
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(lenjack @ Mar 20 2007, 10:47 AM) [snapback]409072[/snapback]</div>
    I am pretty sure it does (can't remember off the top of my head). Get it from Toyota with the oil filter. It is recommended to replace it each time - but it is not crucial.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Yes it does. I think my local dealer sold it separate from the filter, IIRC. My most recent filter purchases have been from metrotpn.com, who includes the washer with their filters.
    I now use a Fumoto Valve, but before I put that on I replaced the washer with each oil change.
    Hey, that means I have washers I won't need. Highest bidder?? :)
  4. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(JimboK @ Mar 20 2007, 03:09 PM) [snapback]409096[/snapback]</div>
    If you run over road debri and break off that valve, you will have bigger issues to worry about than that washer.
    chimiweig likes this.
  5. JimboK
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Rest @ Mar 25 2007, 07:28 AM) [snapback]411834[/snapback]</div>
    No question. As I reported on GreenHybrid, that's a valid concern and something I considered before I bought it. But as I also mentioned there, I have heard of no reports of that ever happening among the many Prius owners that use one.
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I looked around for crush washers figuring that anywhere would be cheaper than buying them from the local Toyota dealer. After looking around, I went to my local dealer and they wanted $0.92 per washer. I put down $10.00 and bought enough to last me more than a few years.
  7. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    I've been re-using the same washer for over a year, and 30,000 miles. Not cheap, just too lazy (or forgetful) to get a new one. So far, no leaks.
  8. Rest
    Rest Active Member
    1,210
    CA
    I re-use crush washers at least a few years on all my vehicles and not one problem.
  9. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    I stripped out a lug nut. I went to toyota for a new one, bought two to have a spare, and asked the guy for a couple of crush washers. He gave me a few. Free. So I changed out my original crush washer after 80,000 miles. Although it was not in mint condition, it had a lot more life left in it and I would have kept using it, but the new ones were free. As long as you don't over tighten, they should last a long time.
  10. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(subarutoo @ Mar 27 2007, 05:11 PM) [snapback]413151[/snapback]</div>
    I have 96544 miles (as of today) on a 2005 pack #4 and change my own oil...have never replaced the washer, and it still doesn't leak.
  11. lenjack
    804
    114
    Pennsylvania USA
    $1 each at my dealer. I have no problem using a new one each time.
  12. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(lenjack @ Apr 3 2007, 10:45 PM) [snapback]417406[/snapback]</div>
    A buck for a washer? Ouch. I think I bought a handful of soft copper washers at one of the big box hardware stores for that a few years back, no problems so far.
  13. c4
    c4 Active Member
    607
    51
    I tend to reuse the washer a few times, with no ill effects, mainly because I have no idea where I put the pack of washers I bought about 9 oil changes ago.. :-(
    Every time I clean my garage, I find the pack of washers, and then I put them away "somewhere safe", but of course, when oil change time rolls around, I've completely forgotten where it is that I've put the washers, so I end up re-using the old washer.. Once in a while, my garage cleaning schedule co-incides with an oil change and I know where my pack of washers is and I'll replace the washer with a new one, but unless the washer is completely mashed out of shape (which means you are probably overtorquing the plug and in danger of stripping the oil pan threads), it shouldn't be an issue to reuse the old one.
  14. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(lenjack @ Apr 3 2007, 11:45 PM) [snapback]417406[/snapback]</div>
    Apparently you also have no problem overpaying. :)
  15. subarutoo
    1,213
    Chatsworth, CA
    <div class='quotetop'>QUOTE(Rest @ Apr 5 2007, 04:03 AM) [snapback]418115[/snapback]</div>
    Do you realize that based on 5000 miles, the cost comes to .0002 per mile! How can you stand to pay for a new washer EVERY time? I'm not cheap, just too lazy to go get new ones.
  16. lenjack
    804
    114
    Pennsylvania USA
    That's right. The amount I'll spend on crush washers over the life of the car, even at $1 each is super trivial. Convenience counts.
  17. comatoes
    comatoes #GreenLife
    288
    17
    Does anyone have a part # or know the size?
  18. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    On an invoice from earlier this year when I bought at a major online Toyota Parts store:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8 Column 9
    0 Part Desc Qty Price
    1 9043012031 Engine / transaxle Engine parts Drain plug Gasket Gasket 1 $0.86
  19. comatoes
    comatoes #GreenLife
    288
    17
    Is that just the rubber gasket which is aka (crush washer)?
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    The crush washer is metal (aluminum maybe, definitely not rubber) with some plastic coating on both sides. Just go to your dealer's parts department and buy oil filter and the washer together. Or do it on-line where there should be a link from the filter to the washer.
