Does the split window make cars look closer?
Discussion in 'Gen 3 Prius Main Forum' started by w1ngnut, Dec 23, 2011.
  1. w1ngnut
    w1ngnut New Member
    south central Pa
    I've noticed on this forum (I'm new) that a lot of people comment on how people behind them ride their bumper. I've noticed it too, but I wonder if it just appears that way or if it is indeed the case that they are too close. Comments?
    51,843
    :car:i think any hatchback makes them look closer than a car with a trunk, but they are still way too close.
  3. qbee42
    3,079
    I agree with this. We humans judge distance partially by perspective. Part of this perspective is the relative size of the trailing vehicle in your rear window. A nearer window makes the trailing vehicle look smaller. A more distant window, such as with a Prius, makes the trailing vehicle fill more of the window, so it looks closer.
  4. Canard
    Canard Member
    223
    Ontario, Canada
    One of my favourite features of the split window (at night) is that tailgater's blinding headlights are blocked by the split. :)
    -Iain
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Yes, it does. Just something you get used to.
  6. Pri4Us
    Pri4Us Junior Member
    82
    Tierra Buena, CA
    That is rather nice... unless the guy behind you is driving one of those jacked-up pickup trucks.
    BTW, I noticed early on that we actually have a bit of curvature in the glass that extends horizontally the full width of the rear window. This causes a slight amount of optical distortion up to near the level of the lowest defroster element trace. I wonder if all Gen III Prii rear window glass exhibits this trait?
  7. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Another factor may be that we tend to judge distance of the car behind by distance from the rear window which we can see clearly rather than the back of our car which we cannot.
    The rear window of a hatchback is noticeably closer to the car behind than the rear window of a sedan. This is particularly true of a hatchback with a Kamm back and a 2 part rear window like the Prius.
  8. NargilFenris
    NargilFenris Junior Member
    75
    Wherever Uncle Sam sends me
    I have noticed it in mine but the distortion seems to be as it gets closer to the bottom.
  9. dsharp88
    dsharp88 New Member
    New Orleans
    I think it just appears that way because hatchbacks have an abrupt "cut off" by design.
  10. cap160
    cap160 Older Member
    78
    Michigan
  11. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    It seems to, though it may be more a feature of the glass than the split. I notice it most when parking - the car I thought I was going to back into is always a safe distance when I get out to look.
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    If you want to see that drivers simply drive too close, just do a brief count when as you pass a marker.
    Many drivers drive too close to each other. It's dangerous, the cause of a large number of accidents, including fatal ones, and it wastes gasoline too.
  13. fulltank
    fulltank New Member
    230
    Arkansas
    Think I have more trouble judging the distance in the front than from the rear. I pull into a spot only to find that I had a good couple of feet to spare? This vehicle is hard to judge the front because you can't see anything beyond the windshield...
