2001 no reverse
Discussion in 'Generation 1 Prius Discussion' started by Mesuec1, Dec 21, 2011.
  1. Mesuec1
    Mesuec1 New Member
    Otis, Oregon
    2001 Prius
    I
    My 2001 Prius has 77K. It has done warning lights before and always been a gas cap that was not tightened or a mis-fire code three times since I bought it last spring. It has been driven very little since Thanksgiving when I was rear-ended and my Camry was totalled. It coughed a little when I started it, but had no problem driving the first 40 miles. I stopped for about 5 minutes to stretch. When I tried to start it to continue to work, all the warning lights came on and it died. I tightened the gas cap and restarted the car to have it die 2 more times. Third time it stayed on and I was planning on limping two blocks to AutoZone to have the codes read, when it rolled to a stop. No forward, no reverse. By the time the tow arrived, it would go forward. The codes were P3101 and 12689.
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Reverse is 100% electric in a Prius.
    P3101 is usually related to dirty throttle body or too much oil put in engine.
    You need to read all codes with a reader than can read INF (subcodes) as well. Autozone scanners are not that great for diagnosing Prius.
  3. Mesuec1
    Mesuec1 New Member
    Otis, Oregon
    2001 Prius
    I
    It has given me the too much oil in the engine code before: usually after I had gone over some bumps then parked on a hill. When the oil level was checked, it was not to the max line. The closest Toyota dealer/repair shop it not the greatest. (They advised me to go elsewhere when I wanted to have cruise added when I was having recall work done.) Their best guy has been out. Guess I will just wait. Thanks.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    How handy are you with cars? This is not really a hybrid issue, it is a lot like having a sticky choke on a carbureted vehicle. Pull the plastic air intake and take a look at the throttle plate. It should be open just a crack.
  5. RW5207
    RW5207 Junior Member
    32
    Dallas, TX
    2002 Prius
    I
    I'm betting if you haven't replaced your traction battery that is ultimately going to be the culprit. I had all sorts of issues on my 2002 (112K miles) and ultimately replaced the inverter (per the codes) with a salvage one and still got the triangle of death. Only after replacing the traction battery with a rebuilt re-Involt battery have my issues gone away (fingers are crossed).
