Installed Eibach Springs Today!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SuperchargedMR2, Dec 28, 2011.
  1. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I got around to installing my Eibach springs on my 10 Prius III. It was pretty straight forward. The fronts were very similar to my 09 Corolla in having to remove the plastic cover & metal tray pan to get to the top of the struts. Pretty easy but tedious. The rears were very simple. I just took out the lower shock bolt & I was able to push on the hub enough to wedge the OEM spring out. The Eibach spring is shorter so it was easier to slip it back in.
    The handling difference is amazing. I also installed my 16" winter wheels & tires that I used on my Matrix so I can see what effect the heavier wheels & tires have on my mpg over the next couple of months.
    Before....
    After....
    Front Eibach vs. OEM....
    Rear Eibach vs. OEM....
  2. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    Looks great man! And I like those wheels. I just installed my Eibachs today too. Did you measure before and after height to the fender?
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Very nice. The handling improvement is much bigger than the appearance change. :)
  4. SuperchargedMR2
    673
    179
    Vancouver, WA
    I thought about it after I had already started. :eek: The drop is only 1.1" according to Eibach but the result of that inch is fantastic. The handling is 10x better from my initial drive.
  5. ockevin
    ockevin Active Member
    493
    148
    Orange County
    Looks great .
  6. Azipod
    Azipod Member
    139
    NorCal
    Did you use the stock shocks or did you upgrade those as well?
  7. movingforward
    movingforward Member
    169
    The Great White North
    Consider doing an alignment now. Zero out the toes and set the cambers to negative. I prefer -1.5 to -2.0 degrees. This will give the car even more grip on turns, not that we drive and turn aggressively with the prii but handling is even more improved with these springs and lower profile tires when you properly align your wheels.
  8. NineScorpions
    375
    64
    I was expecting a little bit stiffer ride, but then again on my old MR2 I think I had the Sportline package with hardly any travel. I still feel quite a bit of travel on the Pri. Do you have aftermarket springs on your MR2? If so, how do they compare to the Pri?
    Check your pm's...sent you something you will appreciate :D
  9. SuperchargedMR2
    673
    179
    Vancouver, WA
    I used the stock struts still since they only have 12k miles on them & the Eibach springs are a mild drop. :D
  10. SuperchargedMR2
    673
    179
    Vancouver, WA
    I will have the alignment checked in a week or so. ;)
  11. SuperchargedMR2
    673
    179
    Vancouver, WA
    I have Eibach springs on my MR2 also. I did recently try some TRD JDM springs but they were way too stiff & low for me so I put the Eibach springs back on. I'm much happier with them on with the Koni yellow struts. :D
    I'll look now at my PM. :)
  12. theangrykorean
    theangrykorean Junior Member
    Va Beach
    I installed my eibach springs about 2 weeks ago on my 2011. I think it does handle way better now. I have driven about 1100 miles since and it looks even better now that it has settled a bit.
  13. mmcdonal
    mmcdonal Active Member
    666
    98
    Columbia MD
    For the posters and OP who have done this: did you need any spring compressor to do this! Or just regular shop tools? Was it a one person job, or we're extra hands required? What was the total time for all 4 corners? I would like to do this myself. Is a rolling floor jack recommended?
    Thanks! And awesome pics.
  14. NineScorpions
    375
    64
    Spring compressors are needed for the front...they are not needed for the rear. A breaker bar (or air wrench), torque wrench, and various sockets are needed. I only needed extra hands to lower the rear housing to pop the springs in/out...so for me 99% one person job. Rolling floor jack works great and two jack stands. I followed the write up someone else did: http://priuschat.com/forums/gen-iii...s-modifications/82404-diy-spring-install.html Apparently 3-4 hours is the going rate...slower or faster depending on your experience and working speed.
  15. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Let me know if you find aftermarket shocks which don't cost arm and leg.
  16. SuperchargedMR2
    673
    179
    Vancouver, WA
    I did it by myself in around 4+ hours. I have several sets of spring compressors so it was simple with my 2 floor jacks that I have. :D
