Battery replacement gone bad? Need help.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wvkrug, Jan 3, 2012.
  1. wvkrug
    wvkrug New Member
    2005 Prius, 90k, original battery I think, started beeping on shutdown, then wouldn’t start today (cold). Got a new battery, but the back hatch wouldn’t open, so I tried to jump it following owner’s manual instructions. Didn’t help, headlights came on at first (although stalk switch was off), but doors/car wouldn’t respond. Disconnected and reconnected jumpers, lights off this time, still no response when trying doors or starting car.
    Replaced battery via the back doors rather than hatch. Now when I try to power on, one push gets me a green light, two gets me a very short whir from the dash and a flashing orange power light.
    I’d prefer a fix that involves me drinking a beer, maybe breaking some stuff with a bat. Thanks.
  2. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    Post pics please! :rockon:
    Are you positive (pun intended) that the new battery had a good charge before installation?
  3. wvkrug
    wvkrug New Member
    I was assuming that the new battery would be OK. Or at least OK enough to get the car going once.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Beeping on shutdown means your keyfob battery is dying. So your fob might be dead. Go get a CR2032 (I think?) battery from anywhere (walmart, radioshack, homedepot, walgreens, anywhere really) and see if your fob works.
  5. wvkrug
    wvkrug New Member
    I'll try it, but they aren't that old, and they both died at the same time?
  6. wvkrug
    wvkrug New Member
    New fob battery didn't change anything, unfortunately. :(
  7. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    Well can you get that back hatch open now (there is a pull cord in there if all else fails)? Make sure you have the cables on the new battery clamped down properly. That sounds like a poor ground.
    Just a thought....
  8. richard schumacher
    7,664
    1,042
    United States
    Depending on where you get it a new battery might not be fully charged. Do you have a voltmeter to check?
    I hope you didn't reverse the polarity, either when jumping or when installing the new battery; if you did then a tow to a dealer is in your immediate future.
