Make a Gen III a plug-in?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by eratosthaenes, Jan 4, 2012.
  1. eratosthaenes
    eratosthaenes New Member
    Chicago
    Hi. I have a 1 week old 2011 Prius, package level 3 (no nav) and I am loving it, especially when I drive around the city for an extended period. However, I also have very serious EV-envy and originally wanted to either buy a Leaf or Prius plug-in, but for a variety of reasons I needed to get this one.
    Here is the deal where my envy comes from: During the week my usage pattern is basically driving from my heated garage approximately 1-2 miles to drop my kid off at school, then let the car sit for 30 minutes and then drive 1-2 miles to the train station where it sits all day in the cold. Then in the evening I get in and drive 1-2 miles home. On many days, this is the entirety of use. So essentially, the car doesnt make it out of ICE warm up mode practically at all and my MPG for those trips are terrible. What I want is to install some sort of plug-in battery system or otherwise modify the car such that I can use EV mode exclusively for these short hops in the morning without engaging the ICE. Any suggestions?
  2. XMAN LIVE
    XMAN LIVE "Just have Fun!"
    271
    49
    Cypress TX
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    So which is better? The pluginsupply unit is a lot more money, is it a lot better product? How big of a kit is needed?
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    There aren't many PIS users in this forum. All of them are Gen II users and are of older system. I think it's because of the cost.
    There are many Enginer users in this forum. A lot of them are Gen III users. A couple of things that plague the Enginer kit are the BMS and the converter. The supplied BMS doesn't manage the batteries very well. It ends up damaging the batteries. There are couple of aftermarket BMSes that will work with the Enginer kit, MiniBMS-Centralized and PacificEV BMS. The latter is designed specifically for the Enginer kit. MiniBMS is a universal BMS that can be wired and modified to work with Enginer kit. I have the MiniBMS and so far it's been working well. One down side to the PEVBMS is it cycles the charger on and off once the battery is fully charged to top balance the battery. This can be good if your battery is out of balance. It can be bad to the high cell constantly being topped off. The soul of the Enginer kit is the converter. It basically works like a step up converter. It converts 48V input to 240V output. Simple enough but it's not. The downside is the converter is not reliable. It over heats and shuts off if used for a long time. Eventually it'll burn out. Warranty is also a bitch because the turn around time can take months.
    There is no support forum for Plugin Supply kits so we don't know what kind of reliability it has. I've seen the kit in person and it's a well designed kit. It uses 76 LiFePo4 cells wired parallel to the traction battery via contactors. There's a piggy back ECU that communicates with the stock ECU to allow more electric assist. The electric acceleration is much peppier with PIS kit than Enginer kit. Enginer kit does not modify the ECU in any way so in order for you to accelerate in EV only, you cannot press the gas pedal pass the half way point of the HSI bar just like the stock Prius.
    Judging from your driving habit, both kit will work. If cost is an issue, I'd go with Enginer kit. However, I would recommend the PIS kit due to much more electric assist than the Enginer kit. With such short distance, You shouldn't have any reliability issues with the Enginer kit. One more thing about the Enginer kit. Its cooling fans are loud as hell.
    If you decide to go with Enginer kit, you'll also have to do either a temperature hack to bypass the engine warm up cycle http://priuschat.com/forums/gen-iii...s/76906-yet-another-thermistor-hack-gen3.html or an EFI hack to disable the ICE completely . In both cases, you need to purchase a Scangauge II to either monitor the engine temperature or to clear warning lights codes.
    There are so many Enginer kits in the wild, you can probably find a used one for way less than $3,000.
    2 people like this.
  5. eratosthaenes
    Chicago
    Wow! Thank you for such a thorough answer. I have a couple follow up questions:
    you wrote "The supplied BMS doesn't manage the batteries very well. It ends up damaging the batteries"
    - By this do you mean there is a chance I will damage the actual Prius OEM battery that is in there now?
    - Also, are you referring to the BMS supplied by Enginer for the kit, or the BMS that is part of the car now (if there is such a thing)?
    What are the pros and cons of each of the two hacks you mentioned (EFI hack to disable ICE completely or Temperature hack? Do you recommend one over the other given my driving pattern (and limited interest in getting technical)?
  6. sub3marathonman
    sub3marathonman Active Member
    557
    75
    Another obscure but in this situation effictive option would be a BMS+ and a couple extra battery packs. I have always liked the "geniusness" of the system but was dissapointed that the support for the system never got developed. There is some discussions of it in the Gen II PHEV Plug-In Modification section.
  7. eratosthaenes
    Chicago
    Ok. I see that solution but I think it needs more technical expertise than I can or want to apply. I really need a "no hassle" solution
  8. SuperchargedMR2
    673
    179
    Vancouver, WA
    After all these years of producing these kits why can't they have improved the ease of having one? Selling a trouble free kit would increase sales 10 fold or more. ;)
  9. cproaudio
    2,401
    762
    CA
    plugin conversion doesn't invent itself. Someone has to research it. Someone has to iron out the bugs. It costs a lot of money to do it. No one wants to fork out their own money to do the research. You can't just strap 4 KW batteries to the HV power line and call it a day. The stock ECU's gonna know somethings wrong and light up the dashboard like x-mas lights. I want a system that's trouble free too.
  10. Randy B
    Randy B Member
    104
    30
    NH
    Gen 3 makes a great plug-in candidate. They share the Gen 2 drive system, there are kits as mentioned above for this system.
    My company, ConVerdant, has installed both for NewEngland customers. There are differences is in function and reliability. Both kits offer some EV mode capability, and both can be over-riden by Toyota's ecu.
    In my experience, the Enginer kit has needed some shop visits so I recommend this kit where the owner is a competent tinkerer or where the installer is within easy commute. It is a good kit at a great price that can hold EV mode [mostly] up to 34mph. The Plug-in Supply kit is a better kit that rarely needs shop visits, but at a higher price. It holds EV mode up to 70mph and does an even better job of sticking in EV mode. For cold starts in winter, there is no absolute solution for EV mode, but the PSI kit is stickier.
