I have got some error
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sanath1978, Jan 10, 2012.
  1. sanath1978
    sanath1978 New Member
    Sri Lanka
    I got following error on my Prius 2007. Please instruct me what to do
    Note- Please see the attachment.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Until someone who can speak Japanese reads this thread you might want to tell the rest of us a little about the Prius you have. I'm assuming it's a grey import Japanese RHD model. What km is it at. Did the car exhibit any symptoms before the error message? Does it still drive? What do you use it for?
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    That has somewhat the look and feel of the transmission lock mechanism is abnormal message. Check your 12V battery first. Maybe ken1784 will see this and translate it. You can write to him at
    PriusChat Forums - View Profile: ken1784
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Yeah the 12v failing sounds reasonable considering the age of the vehicle - esp if it has spent a number of weeks in a container on its way to Sri Lanka. Once its gone you are best replacing it asap as once the 12v fails it can issue all sorts of weird error messages.
    Put it another way - it's cheaper to replace a 12v battery than attempt expensive diagnostics on an imported car. Wait to hear from Ken though -he knows the Prius inside out (literally).
