Ice-Melt
Discussion in 'Gen 2 Prius Main Forum' started by jared2, Dec 5, 2005.
  1. jared2
    jared2 New Member
    1,615
    My driveway is narrow and a fairly steep grade. I need to melt the ice or my Prius will be soon be sliding sideways to the road. Last year I use standard rock salt. Worked great, but it made the plants by the driveway turn brown. Can anyone recommend something that works and will not damage plants? I need it today.
  2. KTPhil
    KTPhil Active Member
    1,379
    22
    Gravel or DG may give a grip without nuking plants.
  3. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I get some pet friendly stuff at a local pet store.
  4. tag
    tag Senior Member
    2,526
    Chicago
    I try to use as little of the stuff as possible but now I always buy Calcium Chloride not rock salt ("Hailte"). Since I switched a few years ago, I've noticed that the grass and shrubs along my driveway come out pretty much unscathed. It also melts ice a lot faster and works at lower temps. The downside is it's more expensive than rock salt.
  5. tochatihu
    tochatihu Senior Member
    9,783
    3,769
    Kunming Yunnan China
    2001 Prius
    calcium chloride (CaCl2) = expensive
    calcium magnesium acetate (CMA) = even more expensive
    Both are effective but less sodium = more happy plants.
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Would it work for you to sprinkle sand, gravel, or maybe kitty litter? (preferably fresh!) You can still get the traction you're looking for without waiting for the ice to melt.
  7. jared2
    jared2 New Member
    1,615
    Thanks for the advice. I just got a 20 pound bag of calcium chloride (Prestone Driveway Heat) I think it will work better and be less damaging to the plants at the front. It was a bit expensive ($10.00) but I really can't drive down an icy hill. I am going to use as little as possible.
  8. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    Go to a feed store and by bulk Potassium CHloride (a fertilizer) It works great and is plant friendly. Cost is going up as people discover this...I got 50 lbs for $8.50.
  9. jeneric
    jeneric New Member
    442
    Redmond, WA
    So you're saying a grappling hook doesn't come standard?
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Also look for Urea, it helps with ice/snow and is friendly to the grass and plants.
  11. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    I have used SafeStep ice melter for several years and have never had any damage to plants or animals. It melts very well too. Don't know if it is available in your area but it is widely avialable in Vermont.
    "SafeStep® Ice Melter
    The Supply Corporation is pleased to offer SafeStep® Ice Melter --- one of safest and most effective ice melters on the market. SafeStep® melts ice and snow effectively at temperatures below 0° F and last up to 2 1/2 times longer than calcium chloride. This easy-to-handle ice melter is non-toxic to children and pets and will not harm grass, trees, or shrubs. "
    http://news.thomasnet.com/fullstory/14537
  12. MNPrius
    MNPrius New Member
    177
    Minneapolis
    This is what I use too - it works fast!
