Missing hubcaps too often?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vafoodie, Jan 21, 2012.
  1. vafoodie
    vafoodie Junior Member
    Yorktown, VA
    I have had my Prius for a year and a half. In that time, I have lost two hubcaps. This seems excessive in contrast to my previous Camrys. Has anyone else had this problem? Do you think they are being stolen or might there be a manufacturing issue?
  2. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I pulled mine off the week I bought the car, and put tiny Toyota caps over the 1 1/2" holes. The alloys underneath look pretty good.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm a taxi driver (and you know how we drive) with 60k+ miles and haven't lost any.
    Must be your driving! ;)
  4. frodoz737
    frodoz737 Top Wrench
    4,701
    2,499
    33
    Lost one during 200 mile trip for Thanksgiving right after 20,000 service. Called Dealership to explain and was told they would replace it when I got back. They also said this happens if not popped back on all the way. I believe them too. I pulled one off the first month when considering center caps, and they are very secure.
  5. Mendel Leisk
    41,479
    Could very well be theft. They're pricey, and not secure.
    The 15" wheel's cover was the THE thing that tipped us towards the Canadian model with 17" wheels. If we were in the same situation now, I might go for the 15" and just pull the covers off right away. Unfortunately then you have an alloy that looks so-so, and an exposed center hub opening to deal with.
    Going with a plastic wheel cover over a 15" alloy was not a good decision by Toyota, IMHO.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    The car is rejecting them, it's like when a wart falls off.
    If for some reason you really want to keep, them, be sure they are pressed all the way into the wheel all around the wheel cover. You can put that kind of cover 1/2 way on the wheel and it will seem like it is fully mounted unless you look closely.
  7. kornkob
    kornkob New Member
    128
    Wisconsin
    Or the roads in your area.
  8. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    I saw one Prius that had a couple of Ty-Wraps on each wheel to ensure that the hub caps would not fall off.
    I took the hub caps off my car. - If you don't have them, can't lose them. (The KISS philosophy really works.)
    Keith
  9. ETC(SS)
    7,164
    It could be the roads, or your driving, or perhaps you took them off to clean the brake dust out of the rotors and didn't get them back on juuuuuuuust right.
    I've only got 22,000 miles in type, but the roads here are NOT what you would call smooth, and I'm NOT a gentle driver with 'my' G3 (cause I didn't pay for it... :) )
    I haven't lost any in 21K, and I've had my covers off 3-4x.
    YMMV.
    FWIW, I agree with the KISS principle.
    Just take 'em off. I'm not really wild about the tuning fork look of the OEM rims......but they're not any worse than the plasticky wheel covers!! :D
  10. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I lost mine 5 minutes after I got home. All four are up in the attic in a plastic bad.
  11. nkirk
    nkirk Junior Member
    Where did you get the tiny Toyota caps??
    Thanks
