So I had 1st rough cold start today
Discussion in 'Gen 3 Prius Technical Discussion' started by cyclopathic, Jan 18, 2012.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    on 2010 Prius with 72K. Wasn't too cold low 40s, so you can't blame
    The fix was to shut it down and then turn on again.
    Engine sounded like it was working on 3 cylinders. It is probably ignition or perhaps valve train issue.. with ignition being prime suspect. If it happens again I'll pull and check plugs.
    Does ZR engine use oil pressure to adjust valving? Need to check oil level then.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    I'd chalk your experience up to the intake manifold problem. Unfortunately, you are beyond the powertrain warranty period, so the fix is not free.
    It wouldn't hurt to check the oil control valve, though.
  3. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Had our 2011 intake manifold replaced yesterday, so far so good. :)
  4. Eoin
    Eoin Active Member
    593
    116
    Long Island
    It happened once to me. Should I take my car in for service? (2010) It has 43,000 miles.
  5. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    cyclopathic,
    Was it the noise that sounded like someone with a hammer was banging on the interior of the hood (for 5 - 10 seconds) an about a 2-4 bang/second rate?
    Did you do anything unusual, out of the ordinary prior to the event? The two times I've had it happen to me, it was because I was moving the car, using all electric and I shut the car down JUST as the gasoline engine was firing up.
    Both times that happened, when I started it up the next time, I got the engine knock event.
  6. reiukitsune
    reiukitsune 2012 weeeeeee
    Pasadena
    I had the same exact issue this morning, exactly once and never again duplicated. The sound was out of character.
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Did you smell gasoline? See any smoke, perhaps black, come out of the tailpipe?
  8. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Unless the OP lives in one of the states that enforce the California Emissions Warranty.
  9. Trev
    Trev New Member
    Taree NSW Australia
    Can also be a fuel injector as it was in our case (sparkplug was tried first). Try a fuel additive.
  10. Pinto Girl
    3,093
    350
    Really curious to see if the intake manifold really fixes the problem. Curious also if there is any part of it that mounts to or somehow has an effect on the VVT-i controller.
  11. Ryan331
    Ryan331 Junior Member
    Cali
    Hi Pinto Girl :)
    VVT-i is a completely separate system, and the logic for them is really sensitive, if there were an issue with the VVT-i getting stuck one way or another/not activating them it'd set a P00** code and MIL would be on..
    Curious, to OP and any who have had the problem, what were the temperatures like? What area do you live in?
  12. Pri4Us
    Pri4Us Junior Member
    82
    Tierra Buena, CA
    In our one occurrence of this anomaly on 9/20/10 I was able to check a nearby weather station's archives and learned the low temperature that morning was 58.5ºF with a dew point 40.5ºF. The previous day's high temperature was 80.4ºF. We are located in the Northern Sacramento Valley, California.
    Since this single occurrence, and after reading PC posts, I have always thoroughly warmed up the ICE before shutting it down. So far, so good. However, since cold soak temperatures of 40ºF were not attained in my experience I doubt my service manager would replace the intake manifold.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    that may have been the case since it did not happen again. Unfortunately have no way of telling what have happened prior to shut off, my SO took car
  14. Codyroo
    1,826
    515
    Pleasanton, Ca
    I'll bet the next time you move your car and shut it down just as the gas engine fires up, it will trigger a "oh no" moment in your head.
    It did for me. I'm glad I had my scangauge when I restarted later, because the engine knock threw an error code and I could clear it so I could drive the car without being distracted by the take car to dealer message.
