strut tower bar
Discussion in 'Gen 3 Prius Accessories and Modifications' started by yeldogt, Jan 31, 2012.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I mentioned in another thread my concern about some "twitchy" behavior I experienced on the highway the other night. This was high-speed driving on interstate 95. Having driven it a few more times at speed -- I notice it is most pronounced on rough roads -- but still noticeable on smooth.
    I can see how a rear sway bar is going to help -- wondering about the front strut tower.
    So many small cars have these -- the links I see are for the GII - but they sell them for the GIII.
    I'm wondering if I may be getting some front flexing and it is changing the geometry.
  2. d0nsut
    d0nsut New Member
    28
    Houston
  3. Azipod
    Azipod Member
    139
    NorCal
    On my Gen2, the tunnel brace made the biggest improvement to reduce the twitchy movement on the highway. The strut tower brace improved the issues relating to heavy cornering.
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    It will so would the adjusting tire pressure and installing rear anti-sway bar.
  5. yeldogt
    810
    313
    NE
    I did check to make sure the tire pressure was correct - and I am doing some research into the different rear sway bars available.
    What is a tunnel brace?
  6. Azipod
    Azipod Member
    139
    NorCal
  7. cyclopathic
    3,292
    547
    2014 Prius c
    In my experience it does better with 42psi front/ 38psi rear. Most people overinflate rears/underinflate fronts and that aggravates problem
    With respect to swaybar there are 2 TRD options, one for 2008+ xB and another from Prius+ package. They appear the same diameter, just different color red vs white. Both ~$240 and ~30min to install.
    Of cause the STB will help too it lessens front flex and makes controlling easier, but air pressure + swaybar would have more impact. STB install takes ~2hr at leisurely pace
    You can also add lowering springs, ~$200+ they will make difference too. But they are not 30min to install good luck
  8. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The Gen III probably doesn't need one.
  9. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
  10. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I just got my front strut brace & 2-point chassis brace from Amazon today. My buddy at Toyota also called me to let me know that my rear sway bar arrived today. :D
  11. cyclopathic
    3,292
    547
    2014 Prius c
    do you have a ramp? it is much easier to install swaybar with back on the ramp.
    also don't forget to load strut bar, otherwise it won't work. Front should be lifted to the point the wheels start sliding but not completely off the ground good luck
  12. SuperchargedMR2
    673
    179
    Vancouver, WA
    yes, I do have ramps. I've added the RSB & FSB on my Corolla & several other Toyotas too. The results were fantastic on mt 09 Corolla so I'm looking forward to getting these installed. :D
  13. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Yes, and also tighten the STB after some time. I have about 3k since installing the STB and the bar needs its preload adjustment again-- its now somewhat loose.
    For the rear, the easiest way to install is as follows:
    1) Lift car and Remove rear tires
    2) Remove bolts to rear shocks.
    3) Slide rear shocks out.
    4) Do install of bar, end links, etc.
    5) REinstall shocks with bolts finger tight
    6) Lower car and torque shock bolts.
  14. Dark_matter_doesn't
    691
    151
    Seattle, WA
    With a little patience, it isn't necessary to unbolt the lower shock mounts. I teased the nuts onto the rear sway bar links thru an existing gap in the trailing arm. And I have big hands.
  15. The Critic
    3,193
    2,333
    CA
    How did you tighten the end links tightly? IIRC that spot is too tight to fit a socket ; I guess a wrench may fit but it would not give you much room to swing.
    MB860 ?
  16. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I hope your significant other wasn't jealous...
  17. Dark_matter_doesn't
    691
    151
    Seattle, WA
    I tightened them with a closed-end wrench inserted thru a hole in the top of the control arm. I spun them on with my fingers until finger-tight, then it didn't take much to finish with the wrench.
  18. vegeto626
    vegeto626 New Member
    37
    Orange County, CA
    This is one of the many threads inspiring me to really consider doing some suspension mods. I have been thinking about doing some and have some concerns. Are the shocks/springs and 17" rims required? I was just thinking about doing the following:
    1. Strut tower brace
    2. Under brace
    3. Front Sway bar
    4. Rear sway bar
    Can someone rank these 4 items in the the amount of impact it has on drivability? Thanks!
  19. Azipod
    Azipod Member
    139
    NorCal
    I have a Gen2. I've done all of the above except the Front-sway bar. Everything is a HUGE thumbs up in its own way. The rear-bar is probably the most exciting, but not doing the others won't get you the full potential.
