Underbody coating on your Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by txl146, Feb 4, 2012.
  1. txl146
    txl146 Member
    301
    NY
    Has anyone sprayed under body coating on your Prius? If so, how's it holding up over time?
    I have applied POR-15 on my Subaru, but I want to know if there is a better kit out there as POR-15 seems to flake off over time.
    Thanks in advance.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I did use a couple of the spray can stuff I mine. It worked fine where there was no existing coating. Where there was, it did not mix well and it dripped off and didn't dry for quite some time.
  3. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Most of the belly is covered by plastic panels. I recon you could spray the areas not covered or remove them all and spray the whole belly and then reinstall the panels.
    Posted from my iPhone via the Tapatalk app.
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    There was a new thread on this two days ago.
    As posted above it does not make sense to coat plastic. The metal parts are already prime and coated to prevent rust. Put coating could create areas for dirt, water, salt, and grim to build up that will cause rust.
    For the last 20 years experts have recommend against rust proofing and undercoating. This is just another item a dealer tries to sell you to put more money in their pocket.
  5. qbee42
    3,079
    The oily coating will most likely do no harm. The hard coatings will add weight and trap moisture. You don't want them on your Prius. The factory coating works well enough.
  6. Mendel Leisk
    41,321
    Have a look under there. There is a real mish-mash of materials and components. I would leave it as-is.
