Wheel/tire experts...17" vs 16"
Discussion in 'Prius v Accessories and Modifications' started by CLUBGUY, Feb 8, 2012.
  1. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Have a v-5 coming....like the slightly taller profile of the 60 series tire on the v-3 over the 50 series of the 17"...thinking a softer ride with the 16"/60
    Talked to the dealer about swapping the 17" wheels/tires for the alloy 16" on the v 3....No decision yet....
    Am I making a big deal over a small difference...or is there an advantage to having the 16"/60...????
    Tire people...?????
  2. Mike James
    Mike James Camaros and Prii go figure
    142
    35
    Lincoln, NE
    YES :D
    YES :D
    I am running 16" in the winter and the OEM 17" in the other three seasons.
    16" = equal better ride, higher MPGs, and cheaper tires
    17" = equal better looks
    If the Prius got 100 MPG and it looked like a Pontiac Aztec, no one would buy it.
    Small differences are big deals to us car guys. :car:
  3. Mike James
    142
    35
    Lincoln, NE
  4. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    You would normally expect a smoother ride from a "taller" tire. Taller means a higher aspect ratio. Likewise you would normally expect better gas mileage from a narrower tire. These are generalizations that are not based on real world experience with the V.
  5. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    I'm looking for a better ride;is it noticable between the 16" and 17"..??...If it's not-a-big-deal, I won't pursue the swap...
  6. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    16's lighter = better power to weight ratio, that improves take offs, slow downs, & MPG. Air pressure in either tire will stiffen up the ride or soften up the ride. Since were at it why not use the Stock Prius 15" wheel? Lighter yet and available unlike the 16's & 17's. I have 3 sets of the touring 16's and they get lower MPG due to extra weight v the 15's.
  7. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    I'm investigating a "swap" at the dealership..v-3 16" for my v-5 17"
    Didn't see a 15" offering....????
    Not sure they will even do the swap...
  8. Mike James
    142
    35
    Lincoln, NE
    1) 15" wheels are not going to fit on the V due to the larger rear disc brakes
    2) I only drove on the 17” wheels for a couple weeks before the winter switch, did not notice a MPG or ride change when I put on the 16” winter shoes.
  9. Mike James
    142
    35
    Lincoln, NE
    I would just keep whatever the factory put on.
    Again the 16" has a little better performance and the 17" has a little better looks. If I drove 25k+ miles a year I could recommend 16" wheels. Under 25k doesn't matter, go with the fancy wheels.
